Help! Arp crank bolt problem!!!
Old Jul 30, 2012 | 07:46 PM
  #21
pirate3's Avatar
Originally Posted by iamkeniff
This is perfect example why everyone should have that crank pulley install tool
Yup. We use a modified(extended) factory bolt.
Old Jul 30, 2012 | 08:10 PM
  #22
chevrolade's Avatar
pipe wrench on pulley...breaker bar on bolt and turn hard it will come out..i use a jack handle for breaker
Old Jul 30, 2012 | 08:19 PM
  #23
2000chevysilverado's Avatar
Sounds like its going to come back out I would get a stock replacement and put back in, just check your threads, double check everything I do know after reading everybodys hrror stories and on my own f ups
Old Aug 9, 2012 | 10:22 PM
  #24
cam's Avatar
cam
So did you get it out or what?
Old Aug 12, 2012 | 10:58 AM
  #25
LS1TRUCKGUY's Avatar
be sure and chase the threads with a tap before threading another bolt into the crank snout
Old Aug 13, 2012 | 07:03 AM
  #26
gsxrluke's Avatar
is it out????
Old Aug 13, 2012 | 01:50 PM
  #27
sand man's Avatar
is it out?
Old Aug 13, 2012 | 02:00 PM
  #28
black04's Avatar
Originally Posted by pirate3
What had happend on mine is I hadn't seated the UDP far enough with the factory bolt before trying to thread the ARP one in and it galled the threads at the end. You'll NEVER break that bolt(tensile strength is ridculous on em) but you'll end up just destroying the end threads. Just keep at it. It will come out eventually.
I've heard of quite a few of them breaking actually.
Old Aug 13, 2012 | 02:24 PM
  #29
nonnieselman's Avatar
yea tensile strength and torsional strength arent the same.
Old Aug 13, 2012 | 03:43 PM
  #30
pirate3's Avatar
On what? lol It's like a 200,000 psi hardened bolt. You would have to be a helluva man with a 10 ft+ breaker bar to snap one of those bolts.
