Unknown driver, ABS light, batt light, etc.
Old Aug 24, 2008 | 11:47 PM
nick993's Avatar
Default Unknown driver, ABS light, batt light, etc.
They all show up while im driving, my gas light stays on and the needle stays at E. my e-brake light stays on. and there is no underline to show what gear it is in. the truck drives like normal. whats going on?
Old Aug 25, 2008 | 01:19 AM
usarmyman's Avatar
I am no genius, and I may be way off. But it sounds to me like a grounding problem or maybe a fuse. Like I said, I may be way off. But that is where i would start.
Old Aug 25, 2008 | 03:09 AM
Parke10's Avatar
sounds like a grounding issue to me.
Old Aug 25, 2008 | 02:57 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
I had this problem back in the winter, clean your grounds on the driver side cab mount, everything should go back to normal after that
Old Oct 28, 2008 | 06:10 PM
nick993's Avatar
Ok, im bring this back. its gotten to where its on all the time. just before it stayed on, i noticed its when i hit the switches. so i believe something is loose even though i checked every ground i could see. where exactly is this ground at the driver side body mount? where the cab bolts to the frame, or the firewall?
Old Oct 28, 2008 | 07:04 PM
venomhp's Avatar
clean off the ground to the frame and body
Old Oct 28, 2008 | 11:30 PM
Piss Pumps for Sale
its the body mount mount on the frame right at the front of your drivers side door, there should be 2-3 wires bolted to the frame, they or the frame may have corrosion on them.
Old Oct 29, 2008 | 06:41 PM
nick993's Avatar
ive checked the grounds that i can see for corrosion. and sanded the ones bolted to the body mount. still doesnt work. any more ideas.
Old Oct 29, 2008 | 09:15 PM
budhayes3's Avatar
PT's Slowest Truck
I've read that the 03+ trucks are prone to instrument cluster problems...maybe something's wrong with your cluster?
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
thunder550
Oct 8, 2015 04:53 PM
97aztecgt
Aug 13, 2015 02:11 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
