truth or fiction???
Old Apr 14, 2005 | 04:09 AM
  #81
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by Naked AV
Well that's just as good as cruise control. Looking forward to the results from some sustained testing.
The other guys' results I'm not sure I believe because there's too many factors that can/are involved. At least with BigTex it will be as you said, a controlled environment so to speak.
Old Apr 14, 2005 | 06:57 AM
  #82
JERRY2500's Avatar
14 Second Truck Club
Yea it's hard to believe it works until you try it. Bigtex's test will be the best because makes the same drive everyday. As far as my testing i never got over 14.5 mpg towing so the 15.9 mpg proves that it helps some. Some people can't even get 15 mpg in a 1/2 ton tow nothing.
Old Apr 14, 2005 | 07:52 AM
  #83
smooth sierra's Avatar
Originally Posted by smooth sierra
my test was done with cruise control at 75 mph on the way there. On the way home I used cruise most of the time at 80 but occasionally kicked it off to hit 85. I have no control over the way my wife drives but she is no speed demon. Also in the past 3.5 years I have owned the tahoe I have kept close watch on the mileage. I have never.......repeat never seen more than 18.2 mpg since we have owned this vehicle.
I will also add the tahoe has just a hair over 40k miles and got the 18.2mpg when it was new. I then saw a slight but steady decline in gas mileage up unitl I ran this test.
chingon please re-read this post. I have been monitoring the mileage on both my trucks since they left the lot. I have ziploc bags full of gas receipts with the mileage written down on them. I have had the tahoe for 3.5 years so I think that rules out a fluke......
Like stated above the truck got 18.2 when brand spanking new on a trip to break her in......never again since. I was lucky to hit 17.xx on the highway before the test. It averaged between 15 and 16 with my wife driving back and forth to work. I will be anxious to see how much difference it makes in the daily driving my wife does. I am still monitoring it. I am sold on the stuff.
I wish I had a bore scope to see if it is blowing the carbon off the pistons. I attribute carbon build up to the dimenishing mileage.....
Old Apr 14, 2005 | 04:57 PM
  #84
ngianop's Avatar
No one has mentioned possible effects on emissions and emissions equipment such as the catalytic converter. Some fuel injector cleaners used to have lead in them that's why they couldn't be used in newer cars but now the cleaners are primarily kerosene-based. Do any of the chemical engineers on this thread know whether or not acetone byproducts would harm/deactivate the catalytic converter?
Old Apr 15, 2005 | 09:56 AM
  #85
TG02Z71's Avatar
Just got back after doing an exact 400 miles on my truck with the acetone in it.
Put the acetone in when I had 10 miles on the tank.
(That far from home to station)
About 80 miles where below 50 mph on surface roads and country roads.
I did 70-75 mph on the freeway, I've done this before without the acetone.
The gasoline I filled up with was non-reformulated (no methanol) 93 octane.
My mileage before was 15-15.5 mpg MAX.
I got 17mpg with 2oz of Acetone per 10 gallons of gasoline.
I think it works, but is it worth it?
If our tanks are 25 gallons I would get 388 miles out of a tank with straight gas.
With acetone added at 2oz per 10 gallons I would get 425 miles out of a tank.
A 37 miles increase, at $2.50 a gallon for premium here thats 2.18 gallons ahead for a grand total savings of $5.44.
A 32oz container of Acetone is about $5.00 here. You would have enough Acetone to do 6.4 25 gallon tankfulls or 160 gallons of gasoline.
This would cost you 15.625 cents per oz of Acetone for a total of 78 cents per 25 gallons if you did the 2oz per 10 gallon ratio.
So spending 78 cents to save $4.66 dollars seems good to me.
I hope I did the all math right.
Old Apr 15, 2005 | 10:45 AM
  #86
TG02Z71's Avatar
whats in this stuff, look here.
http://www.bu.edu/es/labsafety/ESMSD...l#anchor888189
Old Apr 15, 2005 | 11:30 AM
  #87
bodyguard6799's Avatar
Is everyone trying this experiment using just premium gas?? I still only use regular. Has anyone switched from regular to premium just for this experiment??
Old Apr 15, 2005 | 11:39 AM
  #88
TG02Z71's Avatar
Have to use premium, I have an STS with a Nelson tune dude.
Old Apr 15, 2005 | 01:18 PM
  #89
JERRY2500's Avatar
Same here
Old Apr 15, 2005 | 07:03 PM
  #90
bud8fan's Avatar
same here and i used mid grade for my test
