truck won't start!!!!!!!!!!!
Old Jul 21, 2006 | 07:22 AM
TURBHOE's Avatar
Exclamation truck won't start!!!!!!!!!!!
ok if the little car with the lock going throught it is aluminated how do you reset that so you can start your ride back up? ok so what had happen was, i install a remote start on my truck with the key bypass thing. well it works great but every once in a while i will get in the truck and put the key in and turn the key on so i can drive and my little car with the lock thing will be on. so i just shut it off and restart it. well this time (second time) it would not start at all. hit the key and let off and it just turns over for a few seconds and shuts off. last time i pulled the neg cable off just to where it had very little connection and held it there then when the wife tried to start it, it would try then go dead. this earased all the memory in the truck and i tightend the battery back down and it fired right up (works for ses light too) well this morning it was just me so i couldn't get it to work right i guess and the truck will not start at all i had to drive my car to work. so what is the "proper" way to reset this?
Old Jul 21, 2006 | 07:29 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
You need to do a key relearn it sounds like.
I did it once, let's see....
Turn on key to run.....wait till 'security light goes off. wait a minute. repeat 2 more times. Before attempting to start.
Look up "Key Relearn Procedure" before taking the above advice, good luck!
Old Jul 21, 2006 | 07:36 AM
TURBHOE's Avatar
cool thanks i'll look that up too. but one thing the security light wont go out it just flashes.
Old Jul 21, 2006 | 07:44 AM
Whippled 496's Avatar
Yup thats it.....
Make sure doors are all shut and accessories are all off. May want to hook up a trickle charger too, as it may take some time to do.
PROCEDURE:
1.Insert key, attempt to start the vehicle and leave the key in the ON position.
In some vehicles, the Battery and Security light will blink for several seconds, and then shut off. Then the Security light will then remain ON. Leave the ignition ON until the Security light goes OFF. This will take more than 5 mins.
2.When the Security light goes OFF, turn the ignition to the OFF position.
Leave ignition OFF for 20 Seconds.
3.Attempt to start the vehicle again and leave the key in the ON position.
4.Turn the ignition to the OFF position for 20 Seconds.
5.Attempt to start the vehicle again and leave the key in the ON position.
6.Once this entire procedure has been completed (three times) your vehicle will start on the fourth attempt.
Old Jul 21, 2006 | 07:54 AM
Nick™'s Avatar
if you have tuning software just turn off the VATS, the remote start is interferring and the problem will continue. Unless you want to do this over and over again (I don't have ~45 minutes to waste on a random start up) just remove VATS or have the remote start properly installed because something is wrong with the security interface
Old Jul 21, 2006 | 07:56 AM
TURBHOE's Avatar
yeah i found it damn that takes forever huh lol. thanks guys i'll call the wife and have her do that before i get home.
Old Jul 21, 2006 | 08:00 AM
TURBHOE's Avatar
well i did the same setup in a freind car. i think mine is just messed up i may send it back and get a new one. this pisses me off my **** never works right but i can do the same thing to someone alses ride and it will work great. i didn't know you could turn off vats with hptuners. oh well i'll just fix the problem so would rather noone steal my truck.
Old Jul 21, 2006 | 08:04 AM
Nick™'s Avatar
if you disable VATS then no one knows it, so a thief will still think that they have to deal with it, same deterence is still there. To disable VATS in the tune using HP Tuners go to the "System" section (where the fan controls are) and it's on one of those tabs, choose "disable". It'll at least be a temporary fix for now.
Old Jul 21, 2006 | 10:11 AM
TURBHOE's Avatar
yeah i'll prolly do that. i got home and it fired right up lol.
Old Jul 21, 2006 | 11:28 AM
TXsilverado's Avatar
chevy dealerships hate electric starters. if you take it to the dealership with these symptoms you will find all of your electronic starting junk sitting in the passenger seat when you go to pick it up. my buddy bought my old truck from me and did the electric start and had the same symptoms. i told him it was all that crap he stuck in the harness and he wouldnt beleave me. took it to the dealership and they ripped all of that out, along with his alarm
