Thoughts or Opinions on this cam (lq9)
Old Jan 27, 2015 | 10:22 AM
madmann26's Avatar
That cam has similar specs to my Comp LSR 265 grind though the Lunati has a little more lift.
I have LT's, HF cats, CircleD 3200 and 4.11's and love the way it pulls of the line.
It pulls very good up top as well.
Old Jan 27, 2015 | 05:28 PM
Fast_six oh's Avatar
What size tires/wheels are you running? Do any towing??
Im curious as to what kind of power it will make at the wheels..anybody guess what my current setup is making now??
Old Jan 27, 2015 | 09:09 PM
bobfig's Avatar
im thinking 330ish hp at the wheels would be my guess.
Old Jan 28, 2015 | 01:52 AM
assuming thats after cam?? What do you think about the TSP 220 cam for my application??
Old Jan 28, 2015 | 08:18 AM
bobfig's Avatar
i was assuming before can with what you have now.
heres some one with a similar truck as yours on the dyno. and he added a tsp220 cam.
https://www.performancetrucks.net/fo...-graph-519133/
Old Jan 28, 2015 | 06:06 PM
Those are impressive numbers, my truck has the factory dual 2.75" exhaust..wonder how much difference there would be between that and his 3.5" single?? I wouldnt think too much..which cam would you pick for my application? The lunati 217/223 or the tsp 220??
Old Jan 29, 2015 | 09:19 AM
bobfig's Avatar
for me i like being a little different and would go voodoo as a lot of people use the tsp220.
yes i would think i would up the exhaust to 3.5" all the way back also.
Old Jan 29, 2015 | 05:24 PM
Id like to keep it true duals..only other thing ill add is a h-pipe..i would think 3" Duals should be efficient or would stick with 2.5" duals??
Old Jan 29, 2015 | 05:33 PM
bobfig's Avatar
well if you like the way it sounds now then i would leave everything the way it is till you get the torque converter and cam in.
Old Jan 29, 2015 | 06:07 PM
Ok, yeah i like the way it sounds now, but i was unsure which setup would perform better after the cam converter etc..i assume the 3" duals would but would they be worth switching from what i have now (2.75")
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
Denali08
Aug 9, 2015 04:34 PM
06 4.8
Jul 14, 2015 08:09 AM
Aboss
Jul 9, 2015 10:28 AM
