thermostat/water pump gasket
Old Sep 10, 2019 | 08:57 PM
The_W's Avatar
Default thermostat/water pump gasket
I am running a ls1 water pump on my 6.0. The paper gasket has gone bad and leaks. I can not seem to find a gasket to match this water pump. It can be from any 2000-2002 f body. Any help on sending a link would be awesome, local part stores werent worth a ****. I have attached a picture of one i bought but its too big and doesnt line up.
Old Sep 10, 2019 | 09:06 PM
FFDP's Avatar
I thought they just use the o-ring seal like all the others do. I don't remember the last time I've used an actual paper gasket there.
Old Sep 10, 2019 | 09:30 PM
The_W's Avatar
I could be wrong, but this was with the new pump when I got it. But yes it does have an o ring already, and this between water neck and pump.
Old Sep 11, 2019 | 07:00 AM
madmann26's Avatar
I'm with FFDP on this one.
All LS based engines use an oring. There is no need for a gasket for the outlet itself.
Is the thermostat part of the outlet?
The gasket you purchased is for SBC, BBC and Mopar engines.
Old Sep 11, 2019 | 08:22 AM
The_W's Avatar
the thermostat is part of the water neck and not the water pump. So when I took the two bolts out, the tstat was still in the water neck and slid out of the pump.
Junkyard Dog
Mar 6, 2012 04:59 PM
SUPERCHARGE
Feb 19, 2010 11:31 AM
AJII
Sep 10, 2006 08:14 PM
Mangled03gmc
Nov 10, 2005 05:58 PM
redLS1rado
Apr 18, 2005 08:24 PM
