Easiest way to remove water pump?
Old Sep 9, 2006 | 02:56 AM
AJII's Avatar
Default Easiest way to remove water pump?
My dad's 04 Silverado has a leak at the water pump, so we are going to replace the gaskets and hope that takes care of the problem.
So, my question is the easiest way to remove the water pump? Do you guys go at it from the top,bottom? What has to be removed in order to get the pump out?
Thanks in advance!
AJ
Old Sep 9, 2006 | 07:19 AM
ZR1 DREAMING's Avatar
It's real easy, especially if you're just replacing the gasket so not all the hose have to come off. When I swapped cams that was almost the first thing off the motor. I did it from the top starting with the fan shroud and fan(if you have e-fans then they'll be fine where they are). Then you have easy access to the bolts. Good luck, and post up any questions.
Old Sep 9, 2006 | 09:14 AM
sroach20's Avatar
make sure its not leaking from the weap hole. if it is the pump has to be replaced.
Old Sep 9, 2006 | 11:45 PM
AJII's Avatar
We did it today and it was pretty easy. And the truck has 37,000 miles, how convenient is that? haha
And is was the gasket that was leaking, had a spot where the rubber had moved out of place.
thanks for all the help!
Old Sep 10, 2006 | 08:02 AM
Good deal!
Old Sep 10, 2006 | 08:12 AM
why didnt you take it into the dealership? they might have goodwilled it to ya. especially being 1,000 miles over. the cutoff milage for gm goodwilling parts and labor is 60,000 miles.
Old Sep 10, 2006 | 12:46 PM
budhayes3's Avatar
PT's Slowest Truck
Those water pump gaskets leaking seem to be pretty common...glad it went smoothly I was gonna be a wiseguy and reply to "Easiest way to remove water pump" with the answer "with sockets and wrenches" ...but I refrained...
Old Sep 10, 2006 | 12:50 PM
yea i love those water pumps they pay pretty good and i can do them in no time.
(i'm a chevy tech)
Old Sep 10, 2006 | 05:49 PM
AJII's Avatar
I had already prepared myself for that type of answer for asking such a simple question on a forum like this! lol
And we tried two different dealers to get it replaced under "goodwill" and neither of the two would do anything about it. So much for customer appreciation!
AJ
Old Sep 10, 2006 | 06:58 PM
wow, they must not want the work for their techs, we would have taken that in a heartbeat. im a gm tech as well.
