Synthetic or Conventional oil at 57k?
Old Mar 13, 2007 | 01:57 PM
03GMC's Avatar
Default Synthetic or Conventional oil at 57k?
Trying to decide what type of oil to run at 57k on a 5.3. Interested in running Amsoil, Royal Purple or Mobil 1 but dont want to spring any leaks with almost 60k on the clock.
Do you guys see any real results from running these synthetic oils?
Old Mar 13, 2007 | 08:21 PM
06WT's Avatar
There is no real proof to back up gains from syn oil, but if you feel better with it in then youll be fine at 67k +. The only time you DONT want to use syn is in the first 2k-3k on a new motor, during the break in. But be shure to change it 1k from first fill because synthetic pulls all the old deposits from the petrolium based oils and may clog the pick up. So fill it up change it at 1000 on the syn and re fill and your good for 4k-5k
Old Mar 13, 2007 | 09:32 PM
1FUNZ71's Avatar
14 Second Truck Club
i have swapped to amsoil in the past 4 vehicles when they had under 200miles on them, never a problem. Motors are already broke in.
Old Mar 15, 2007 | 09:30 PM
dirtyratt's Avatar
synthetic oils tend to make your seals leak more from what i have seen
Old Mar 16, 2007 | 01:10 PM
03GMC's Avatar
Ok so what do you guys reccomend for a 5.3 at 57k?
Old Mar 16, 2007 | 03:40 PM
chevyguy7802's Avatar
My cousin went to mobil 1 at 65k he's got over 100k now and no leaks.
Old Mar 16, 2007 | 04:02 PM
Snacktime's Avatar
Made in South Korea
I would use dyno oil if you service every 3k and Syn if you go 5k+ per service.
Old Mar 16, 2007 | 04:07 PM
1FUNZ71's Avatar
AMSOIL Series 2000
Old Mar 16, 2007 | 11:28 PM
SnakeOiler's Avatar
Put in whatever you want (or what you can afford). I've used Mobil1 since day1 on my car and truck.
Old Mar 17, 2007 | 01:00 PM
krambo's Avatar
Mobil 1 10W30 and a good filter.
