Stock Wiring is a MESS
Old Jul 14, 2008 | 11:50 AM
regency's Avatar
Default Stock Wiring is a MESS
Has anyone found a way to clean up the wiring without having to cut, lengthen, and resolder the harness!!! I hate the big roll of wires sitting on the top of the intake
Old Jul 14, 2008 | 04:00 PM
oldred95's Avatar
Denali engine cover. It would be practical to lengthen the harness to get it out of the way and even then it will always be in the way of something else. I would think a 3 piece engine cover would be easier/cleaner. After all, I can't see it from my house.
Old Jul 14, 2008 | 09:21 PM
regency's Avatar
i have a LS6 intake so i cant really use the three piece cover! but i could use some corvette covers im not sure if i really like them though
Old Jul 14, 2008 | 09:24 PM
GMCtrk's Avatar
which spark plug wires are those? They look OEM.
dirt track racer 81's Avatar
mine is pushed outside the coils on the drivers side..its farther down now than in my sig pic
Old Jul 15, 2008 | 09:25 AM
regency's Avatar
the plug wires are oem, i dont see aftermarket helping since they are so short and big!!!
dirt track - im going to see what i can do with them like maybe going straight back to the brake booster then under it and across the firewall. i'll probably have to splice every dang one of them!!
I have deleted the EVAP and plan to swap to the LS6 PCV system. I just want it cleaned up. Can i delete the charcol(?spelling?) canister????
Old Jul 15, 2008 | 11:24 AM
budhayes3's Avatar
PT's Slowest Truck
Deleting the EVAP stuff may give you problems with the gas nozzle turning off while fueling, not allowing the gas tank to fill, not to mention EVAP codes and an incomplete EVAP monitor (although the codes can be handled with tuning software I believe)
Old Jul 15, 2008 | 03:05 PM
regency's Avatar
well i already have the valve up front took off and code deleted! i think im just going to take that line loose from the canister and put a small filter on it and leave the canister in place and hooked up.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
vortecyota
Jul 23, 2015 08:26 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
4B11T
Jul 13, 2015 03:48 PM
