Speed Engineering header clearance
Because they advertise updating the y pipe which mates to their lts to specifically accommodate a 80E. Wouldnt you assume if someone was making special revisions to a y pipe the headers would at least clear lol.
Sounds like they are saying there is a y pipe to clear an 80e, you're saying the headers hit, so maybe the headers work with the tab cut off the trans and the 80e y pipe is different to clear another part of the 80e that the normal 60e y pipe wouldn't clear.
I didn't know they advertised them to work with a 4L80 so yeah man if they do advertise it to fit and doesn't I'd be pissed too.
Fortunately it's a super easy fix.
If you just need a little room from the header you can try what I did. I started the truck and let it run and revved it a lot to get a bunch of heat in the headers. After getting them hot I ratchet strapped the header to the frame and made a light pull on the header until it moved over the 1/8th inch I needed it to move.
I set out straps and got a plan before getting them hot, I also quickly wrapped the collector with foil so it wouldn't burn the ratchet strap
They simply advertised the y pipe has been updated to fit the 80e, it wouldnt make any logical sense to update a y pipe that goes with those headers if the headers dont fit. thats really putting the carriage before the horse. anyone buying the y pipe is buying the headers in most cases. could have been a simple update. have since hacked my tab off lol. truck goes for a dyno tune tomorrow morning. only lot drives atm.
zblee
63
06-10-2023 01:25 PM
JohnDaMan
08-29-2014 10:58 AM
M.Roberts
13
03-23-2004 08:17 PM
