Run out of gas with 6 gals in tank, twice! Fuel pump?
Old Jun 14, 2012 | 05:22 PM
  #21
CashDudeHomie's Avatar
There's a TSB or memo or whatever to replace the connector with an updated version when you change out the pump. It's for the square connector. I think you have that one. Not sure if it is related to your problem or not though. http://www.acdelcotechconnect.com/pd...tsb_05D-83.pdf
Nevermind. It says excludes Flex Fuel. *foot in mouth*
Old Jun 14, 2012 | 05:55 PM
  #22
TX Tahoe Z71's Avatar
Thanks for checking though, hopefully it helps someone else who comes across the thread
Old Jun 15, 2012 | 12:17 PM
  #23
Amazon is sending me another one, call took 7 minutes total, I just send the old one back with their label attached when I can. The easiest warranty/return claim I have ever had
Old Jun 15, 2012 | 02:04 PM
  #24
nonnieselman's Avatar
Amazon is good to deal with.
Old Jun 17, 2012 | 09:23 AM
  #25
sleeperlqx's Avatar
had to redo the electrical connection on top of the tank, new connector I believe its a TSB that corrosion builds up in the contacts.
Old Jun 17, 2012 | 11:18 AM
  #26
I'll check on that, and I'll compare my connector type to the TSB posted above. Thanks for the info. Would that red battery corrosion spray help prevent future corrosion?
Old Jul 22, 2012 | 09:14 PM
  #27
Replaced the pump today. Time will tell if this one is any better.
Side note, the locking ring on the top was a b*tch to get back on using channel locks. I went to O'Reillys to get the special tool for it, but they initially had no idea what I was talking about, then looked it up and found it in the warehouse only, so no help there. And I did it with about half a tank of gas (no choice, have to ship the old one back to Amazon by the 24th), and must have spilled a few gallons out after disconnecting the filler hose, but luckily cleanup was easy, just wait half an our and it's gone Had a fire extinguisher handy just in case.
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
