right side axle shaft removal
Old Apr 16, 2016 | 04:49 PM
40series's Avatar
Default left side axle shaft removal
i replaced the front left axle seal , which was supposed to be the hard one, well the right side wont budge . i tried beating on the half shaft itself but it wont move
any body have any ideas as to how to get the right side shaft O U T
Old Apr 17, 2016 | 01:36 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Is the left side the short Side?
If so the clip is probally stuck. I had to cut one off. The diff shop tells me it's quite common.
Old Apr 17, 2016 | 02:51 PM
40series's Avatar
Default looking at slide hammer or drift punch
im looking to do it with a drift punch or slide hammer also the vent tube might be the prob on the driver side.
Old Apr 17, 2016 | 05:24 PM
FFDP's Avatar
THe passenger side shaft has to come out with the axle tube itself. So unbolt the tube from the diff housing and don't lose any of the springs/gears when you pull it down.
The drivers side you can just smack out with a hammer.
Old Apr 17, 2016 | 10:05 PM
Wolftrk99's Avatar
Ive found its easier to drop the diff out to change axle seals, the right side tube and the shift collar and spring are a pain toget lined back up in the truck...
Old Apr 18, 2016 | 05:52 PM
40series's Avatar
Default driver side
i hit the drivers side a few good times and gave up on it, i saw i drawing of a manual pic that look like they put a drift punch in one of the holes off the center which would give good leverage to free the shaft otha slide hamme ris the last resorter than that
Old Apr 22, 2016 | 06:54 PM
Cleanoh4's Avatar
Registered User
Drivers side can be beat out, may take some persistence, but it should pop. As stated for passenger side you should drop the tube.
Old Apr 26, 2016 | 08:05 PM
tgui's Avatar
I've done both with diff on the truck. I did it again when I rebuilt the entire diff. It's soooo much easier to drop the damn thing.
Old Apr 26, 2016 | 08:54 PM
Wolftrk99's Avatar
If the snap ring is bound up sometimes you need to smack it back in to reseat the snap ring...
HEMI450HP
Apr 15, 2016 03:33 PM
Choda
Apr 14, 2016 08:00 AM
B&M Racing
Apr 12, 2016 12:06 PM
Mean Green z28
Apr 11, 2016 06:56 PM
4Runoma
Apr 11, 2016 06:44 PM
