Which is the right e-fan to use....
Old Mar 25, 2011 | 06:12 AM
lady3bglover's Avatar
Default Which is the right e-fan to use....
I have a 5.3l with 60cc Patriot Heads and the ls1 fans that i have I don't think are doing the job. We're still getting a little warm under the hood sitting in traffic.
I also have a 34" Genesis Aluminum radiator, new water pump and stat.
Would the fans from a 2500 or 4x4 do the trick, and could I use the same wiring harness?
Thanks... Lisa
Old Mar 25, 2011 | 01:49 PM
brent5631's Avatar
The factory truck fans will work. i think that the plugs might be different though. Otherwise you could use the same harness.
How are you liking that rad? Mine is still working really well.
Old Mar 25, 2011 | 04:40 PM
Radiator is a great buy, and works like a charm.
Old Mar 25, 2011 | 04:51 PM
Swerve7rpm2000's Avatar
i have the genisis three core all aluminum ,160 stat, and two 14" flex a litte fans..... Works like a charm.... And you mean getting a little to hot under the hood what temps are u referring to?
Old Mar 25, 2011 | 05:51 PM
Engine temp. I have an Aeroforce gauge and I have it set for the engine and trans. Trans is normally below 20-30 degrees from engine.
Last week I was sitting in traffic on the highway, and I hit 230 on the engine. That's a little high for me, and it was only in the high 70's that day.
And I have the 50/50 Dex-cool as well.
Lisa
Old Mar 25, 2011 | 09:15 PM
andrew383's Avatar
traveling mod
Sounds like one of the fans isnt working to me...
Old Mar 25, 2011 | 11:26 PM
383.. I'm thinking that too...
Just can't decide to do with the dual fans or one big one.....
Old Mar 26, 2011 | 01:46 AM
brent5631's Avatar
I would just go with factory duals. You dont need to have the one running full blast all the time when the A/C is on.
Old Mar 26, 2011 | 06:34 AM
Brent.. thanks for making me think of that...
I have the harness to run the two.. why not use it.
Old Mar 26, 2011 | 04:01 PM
So what are the CFMs on the stock fans?
