Which is the right e-fan to use....
Lisa, IDK stock CFM fan ratings, maybe someone can dig em up for ya, dealer maybe?
FWIW, my e-fans were $150 from an '05 'Hoe. I'd hoped for $125, but I wanted to do the swap, so I didn't wanna keep waitin, but it'd be a good score in the $100-150 range. W/. all the trucks round Houston, should be pretty common in a 'yard.
And yes, I know as it gets warmer down there, ya wanna fix it before too long. 230° is a lot!!!
IDK how long ya been running your current e-fans, but do ya know if they were configured for a 2 pin setup & the tune set that way. My guess if Charlie or Justin did the harness & tune, then yes. What are fan settings on & off, Fan 1 & 2?
My 05+ truck fans have been absolutely flawless (knock on wood). If you find that one of your fan motors isn't working, I'd take the opportunity to upgrade to some 05's. You can use your existing harness, just need to change the plugs to the fans. I had some plugs not too long ago but sold them, so I can't help you there
Another thing to consider is your fan turn on/off settings...if the truck is heating up, and the fans aren't turning on (assuming that the fan motors are both functioning), you might need to turn the fans on a little sooner, or have them run a little longer...
1/4" female spade terminals work good.. atleast thats whats on my fans
I had a brush mess up on my LT1 fans years ago and it would struggle to turn half speed and made bad noises.. but up to that point i never had any problems.
Might want to check and see if both fans are turning when they are suppose to....
My 05+ truck fans have been absolutely flawless (knock on wood). If you find that one of your fan motors isn't working, I'd take the opportunity to upgrade to some 05's. You can use your existing harness, just need to change the plugs to the fans. ...
Hey guys.. so this is what I've come up with... it isn't the fans. Yeah.. the 2nd fans turned on at 174 and I watched for 10 mins, temp didn't budge.
I even watched the 50/50 Dex and made sure there wasn't any air pocket in the line (gave a little burp), and the temp still didn't budge.
Hubby told me to buy a pony(helper) fan to mount on the front of the radiator. So now we'll see.
Thanks for the posts.. I will keep you updated.
Lisa
Lisa
lycominghunter
26
Sep 25, 2015 07:50 AM
