pitting
Old Sep 19, 2011 | 08:46 PM
slow.8's Avatar
Default pitting
theres some pitting around a few of the water jackets on the block. should i be worried about this, i know its not IDEAL, think the head gaskets will seal up?
Old Sep 20, 2011 | 02:22 PM
slow.8's Avatar
guess ill find out
Old Sep 20, 2011 | 05:50 PM
budhayes3's Avatar
PT's Slowest Truck
Do you have any pics? Some pitting is bound to happen...I've sealed up some pretty nasty aluminum heads, manifolds, etc in the past and gotten lucky. On vehicles with paper or composite gaskets, I've often coated the gaskets with a thin layer of Toyota black FIPG (basically Toyota brand RTV, but I've found that it works better than RTV does), and sometimes have used it on rubber gaskets/o-rings with good results. I'd try sealing whatever it is that you're sealing the right way though, and if you end up with a leak, swing by a Toyota dealer and shell out the dough for the oil pan/cam housing FIPG...the stuff truly is awesome.
Old Sep 21, 2011 | 09:06 AM
slow.8's Avatar
ill put up some pics, thanks
Old Sep 25, 2011 | 09:53 PM
slow.8's Avatar
the pics i took sucked. this ones of the knock sensors.... something looks off with the one on the right.
Old Sep 26, 2011 | 08:44 PM
slow.8's Avatar
pictures
Attached Thumbnails pitting-enginepics2-008.jpg   pitting-enginepics2-009.jpg   pitting-enginepics2-012.jpg   pitting-enginepics2-016.jpg   pitting-enginepics2-019.jpg
Old Sep 26, 2011 | 09:37 PM
slow.8's Avatar
before pic of the pistons
Old Sep 28, 2011 | 10:40 AM
slow.8's Avatar
i think i may throw some rtv on the waterpump gaskets. no comments?
Old Sep 28, 2011 | 11:52 AM
budhayes3's Avatar
PT's Slowest Truck
Whoa, that's pretty bad, wasn't expecting to see so much corrosion, and so deep looking also. If I were putting it back together, I'd also put something on the block side of the water pump gaskets, only I like to use the black Toyota FIPG oil pan/cam housing sealer, which is like Toyota's version of RTV, except it has a bit of a different texture to it and is very forgiving. Just my preference, if you've had good luck with RTV in the past roll with what works for you!
Old Sep 28, 2011 | 12:38 PM
slow.8's Avatar
thanks again, man. ill have to run down the road and see how much they want for that sealer.
gaps
Sep 2, 2015 01:19 PM
jmarkway
Jul 18, 2015 09:23 PM
white1
Aug 21, 2006 10:51 PM
