Pick n pull 5.3 is it worth using?
Old Jan 18, 2016 | 11:15 PM
  #31
1FastBrick's Avatar
Custm2500's Rude Friend
If they bored it yes, the cost would go up. To run a Ball hone through it though is very inexpensive.
When I do mine, I do a thermal cleaning which takes it down to raw metal. That's way more expensive and requires boring afterwards.
It's usually around the $500 range to go that route.
The last one I did was only Ball honed, but I had it decked. Plus sending pistons out for coating. New arp rod bolts checking everything for size, Mocking it up to measure deck height so that I could get the desired Height out of the hole. Balancing the rotating assembly, Nitriding the crank and polishing it. The bill was around $900 In machine work and Labor. I went through like 3 blocks to get exactly what I wanted with good standard bores and to be able to Deck it to my spec.
Old Jan 19, 2016 | 09:24 AM
  #32
Shtbox's Avatar
Originally Posted by Wolftrk99
Holy crap!!! Was that the machine shop???
No that's where I was tearing my engine apart that last bay then out of no where smoke just started rolling into our shop then we called the fire department.It was pretty crazy I had to go back the next day to get my main caps and all my parts
  #33
Shtbox's Avatar
Originally Posted by FFDP
Looks like a scrap building judging by the quota on the wall.
Yea I work for 1800 got junk part time
Old Jan 19, 2016 | 10:44 AM
  #34
Shtbox's Avatar
No. The freeze plugs unscrew on these engines.
Cam bearings with replacement is usually around $75.
Depending on how they clean they clean the block will determine the price. If they just wash it. Probably $50.
A standard ball hone depending on the shop is around $65-$80
Doesn't sound like they are Familiar with LS based Engines. Might want to shop around.
Yea this a one man very small machine shop...yea I better call around lol I use this guy when ever I do head gasket jobs for a resurface but maybe not for this project.Dang you went thru 3 blocks for the right set up that's some serious patients lol
Old Jan 19, 2016 | 11:37 AM
  #35
Wolftrk99's Avatar
Winder if the guy was quoting on an older sbc... That woudl make more sense with the freeze plugs and everything...
Old Jan 19, 2016 | 09:54 PM
  #36
1FastBrick's Avatar
First engine had rust in the cylinders.
Second block I bought, The deck's were not true do to core shift. It would require a serious cut to get them both even. Would require special head gaskets but the machinist refused to cut it that much.
Bought another engine but it had spun rods and cam bearings so I promptly returned it.
Bought another short block from a member on here. Only needed the block and it ended up fitting the bill for what I needed.
Old Feb 12, 2016 | 09:08 PM
  #37
Shtbox's Avatar
Hey buddy do you think these pistons would be a good choice for the fly top 5.3 build or no??http://m.summitracing.com/parts/slp-h1132cpa75mm
Old Feb 13, 2016 | 12:20 AM
  #38
1FastBrick's Avatar
Hey buddy do you think these pistons would be a good choice for the fly top 5.3 build or no??Speed-Pro Hypereutectic Pistons H1132CPA75MM - Free Shipping on Orders Over $99 at Summit Racing
If you have rods with floating pins, then Yes.
If you have pressed pins, then No They would not work.
H855CP75MM Pressed pin application
H1132CPA75MM Floating Pin rod
Does the block need to be bored?
That is for a .75MM over bore which is equal to about .030 over bore.
Old Feb 13, 2016 | 01:44 AM
  #39
Shtbox's Avatar
O no the blocks not bored it's stock!if I get it boared are these w good choice or different brand??
Old Feb 13, 2016 | 08:19 AM
  #40
1FastBrick's Avatar
That piston is available in different sizes from that manufacture. I would talk to a machinist first so you get the right size. I believe they offer standard bore, .020 over, .030 over, .040 over, .060 over.
I prefer to go with the minimum requirement. Large sizes do not gain you anything in the power range.
The brand is fine for a naturally aspirated engine.
johna7200
Apr 10, 2016 07:40 PM
JordanH
Jan 9, 2016 06:45 PM
Shack
Dec 31, 2015 01:22 PM
THUNDERXx
Dec 16, 2015 12:21 AM
rs50pilot
Dec 13, 2015 12:54 AM
