Intake removal
Old Dec 14, 2015 | 08:23 PM
THUNDERXx's Avatar
Registered User
Exclamation Intake removal
I have a 2008 5.3 and i am doing the Ls3 conversion. When i pull the intake off, do i have to pull the injectors off? or the fuel rail? or can i keep them all together?
Thanks
Old Dec 14, 2015 | 09:49 PM
Wolftrk99's Avatar
Keep them all together
Old Dec 14, 2015 | 10:29 PM
MrHorsepowerLSx's Avatar
11 Second Club
Ummmmmm.....you need to have a 4" bore for LS3 heads to work, so that way the valves don't hit the top of the block
Old Dec 14, 2015 | 10:44 PM
Wolftrk99's Avatar
I missed the 5.3.... What are you converting exactly??
Old Dec 14, 2015 | 10:49 PM
11 Second Club
He says a 5.3........ My guess would be heads/intake. Either way it won't work
Old Dec 14, 2015 | 11:58 PM
THUNDERXx's Avatar
Registered User
im putting the BTR stage 3 truck cam in. Im doing the DOD delete so i have to tear down and put new lifters and lifter trays, valley plate, springs, push rods, and a 3 bolt cam gear. i just didnt want to have to mess with the injectors at all.
Old Dec 15, 2015 | 07:09 AM
Tigger Welder's Avatar
The injectors and fuel rail attach to the intake, so when you pull the intake, it all comes out as one piece. So in answer to your question, you don't have to mess with the injectors at all.
Old Dec 15, 2015 | 08:08 AM
THUNDERXx's Avatar
Registered User
okay cool! Thanks a bunch!
Old Dec 15, 2015 | 08:53 AM
11 Second Club
Was the "LS3" conversion a typo? Or are you just doing a cam swap and deleting the DOD? Because LS3 heads ARE NOT going to fit on your small bore 5.3
Old Dec 15, 2015 | 05:04 PM
Wolftrk99's Avatar
Thinking he meant ls3 valley cover conversion...
