Pick n pull 5.3 is it worth using?
Old Jan 10, 2016 | 09:21 PM
Shtbox's Avatar
Default Pick n pull 5.3 is it worth using?
I went to pick n pull the other day and there's a couple 5.3s out there with the intakes missing,i'm sure it's been rained in but would it be worth buying?I just want it for a short block to make a iron L33 for my truck
Old Jan 10, 2016 | 09:35 PM
FFDP's Avatar
Ask to pull the cylinder heads real quick. Or just turn the motors over by hand with the plugs out, then see if any water is in there.
You can always save them if they havent been sitting forever. Remove the pistons and clean up the cylinders and away you go.
Old Jan 10, 2016 | 09:56 PM
Shtbox's Avatar
Yea it's a pretty unsupervised pick n pull so long as the motor spends free I should be able to save it?
Old Jan 10, 2016 | 11:10 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Basically, Yes.
If the motor will not turn freely 360 degrees, It has corrosion on the cylinder walls or other issues.
If it will turn 360 it should be useable. I usually turn it over 2 or 3 full times to be sure.
Pull a valve cover and look for oil sludge or build up. Those usually lead a harder life.
Old Jan 10, 2016 | 11:27 PM
TXsilverado's Avatar
Or just find a more organized yard...slme yards around here offer some kind of warranty.
Old Jan 10, 2016 | 11:41 PM
Shtbox's Avatar
Basically, Yes.
Thanks 1fastbrick I'll be sure to follow that check,Have you ever seen a crank so bad it was unusable or is that unheard of on a 5.3??
Old Jan 11, 2016 | 12:01 AM
1FastBrick's Avatar
If you rotate it back and forth Clockwise, Counter Clockwise and check for loose rods you should be ok.
If it was run low on oil and spun the bearings, it can be damaged beyond repair.
I opened one up like that and the cam bearings also came out with the cam.
I try to inspect them as much as I can before purchasing an engine. I would pop the pan off and look for bearing material coming out of the side of the rods. Also look for the cam bearings coming out of the journals. Look for the crank casting number to verify it is a 5.3L
casting number should be 12552216 for a 5.3L
Old Jan 11, 2016 | 12:11 AM
Shtbox's Avatar
Sweet thanks for the info!!!I'll be going Thursday at 92.00 bucks that seems like a good deal
Old Jan 11, 2016 | 12:13 AM
1FastBrick's Avatar
Can't beat that with a baseball bat!
Old Jan 14, 2016 | 12:17 PM
Shtbox's Avatar
Well all the 5.3s at pick n pull wouldn't spin 360 I tried and tried and wouldn't budge.So I found this guy on craigslist says he's got a 5.3 but it's got 300k and will sell me the long block for 200,he said it uses oil but starts and doesn't knock should this 300k matter even tho I'm replacing the pistons,rings and bearings??or should I steer clear of that deal??
