need some help with electrical problems
Old Sep 13, 2009 | 12:19 AM
supermilano's Avatar
Unhappy need some help with electrical problems
i am currently having some issues with my 2004 regency rst and figured you guys could help
1:
for my 2004 chevy regency rst the oil pressure gauge on the cluster isnt working properly (it is not staying steady some days it will work others days it will and on those days it will peak or completely bottom out where its pointing towards the gas gauge below it).
is there a short? how could i diagnose/fix the problem? sinces its electrical related should i take it to a pro?
and every once in a while my voltage gauge and gas and temperature gauge will do the same thing.
2:
on my temperature instrument panel, the part where you can adjust it hot/cold air for the passenger side: one of the light is out, should i take it out and replace the bulb myself? or should i also just get a new one
i appreciate any help.
Old Sep 13, 2009 | 12:54 AM
Mangled03gmc's Avatar
Baltimore Whore
I duno if you can replace just a bulb, is it digi or manual.. Also the cluster might be wacko, might want to check into a new one
Old Sep 13, 2009 | 02:40 AM
skolman91's Avatar
there was a recall or tsb on gauge clusters acting the way your describing (sticking or weird acting stepper motors). think they extended the recall or tsb timeframe so it might still be going on check with your dealer.
i was informed of this by the person i bought my truck off of when i got the truck. i decided to get a escalade cluster instead of waiting to see if it would happen, so i have no personal experience with said problems but know they exist. hope that helps
Old Sep 13, 2009 | 08:34 AM
thanks! that was really helpful. i will definitely look into it and keep you guys updated!
appreciate it!
Old Sep 13, 2009 | 08:41 AM
budhayes3's Avatar
PT's Slowest Truck
When the bulbs went out on my climate control panel, I had to de-solder them off of the circuit board and match them up at Radio Shack, and solder the new ones in.
Old Sep 13, 2009 | 10:18 AM
btw for fellow regency owners was yalls suspension a special color? like was the springs red or something? btw whats the redline on the 4.8
Old Sep 14, 2009 | 09:48 PM
went to the dealership today, i can still get it fixed under the warranty but since Regency is out of business, they can only replace it with the stock one, =/
so i just opted out of it, and send it out to someone to get it fixed
Old Sep 14, 2009 | 09:49 PM
Old Sep 14, 2009 | 10:02 PM
skolman91's Avatar
should of told them to get you a escalade or ss cluster, better than stock and if they will do it no money out of your pocket..
Old Sep 16, 2009 | 10:40 AM
will a newer regency cluster fit my truck?
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
