intermitent long crank
Old Sep 29, 2015 | 11:33 AM
SSpeeDEMONSS's Avatar
Default intermitent long crank
My fuel pump just went out so I replaced it. Before it did I was having to crank the engine over for 3 or 4 seconds to get it to start. Changed the pump and fixed that issue. A few days later it started doing it again. Now it fires up first thing in the morning but after that it takes a while to start. Going to change the fuel filter right now but not sure what else it could be. Any suggestions.
Garrett
Old Sep 29, 2015 | 03:03 PM
Wolftrk99's Avatar
Check your Fuel pressure regulator and what brand pump did you put in it???
Old Sep 29, 2015 | 05:10 PM
Suburbazine's Avatar
Sounds like a failing crank/cam sensor. Check fuel pressure first though, you should have 48+psi key on engine off and 55+ key on engine on.
Old Sep 30, 2015 | 01:09 PM
I will check the regulator today. I will need to get a gauge to check the pressure though.
Garrett
Old Oct 3, 2015 | 01:00 PM
Pulled the vacuum line and it was full of fuel. Replaced the regulator and fuel filter and ito good to go. Thank you for the help.
Garrett
Old Oct 3, 2015 | 08:08 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Thanks for the update!
Old Oct 3, 2015 | 08:21 PM
Wolftrk99's Avatar
Glad you got it!!!
flatblack83
Jan 3, 2026 07:10 PM
mikeyjm1
17
Oct 29, 2015 11:04 PM
kalikid06
20
Oct 13, 2015 07:37 AM
Justin87gn
Sep 10, 2015 12:06 PM
zraffz
Sep 8, 2015 07:40 PM
