I installed the Dynatech headers today!!!
Old Jan 6, 2005 | 12:00 PM
  #31
04sierra's Avatar
Originally Posted by onequick5.3
As far as buying the kit used, you could reuse the stock manifold bolts but I would buy some new gaskets since there is a possibility to bend the gaskets.
Thanks!
Old Jan 6, 2005 | 02:36 PM
  #32
Also I took my truck back to my buddies garage and was unable to put it on the lift but he did drive it and said it had no exhasut leaks at all. Its just the new sound that Im gonna have to get use to. I do think that there is close clearance as stated above with the crossmember and the pipe so Im gonna have to check on that as well. Im gonna have to get all the little bugs worked out and then i will be happy.
Old Jan 6, 2005 | 08:59 PM
  #33
SnakeOiler's Avatar
Here are some pictures I took. The first one, although blurred (damned autofocus), shows how little room I had. This was causing a lot of rattling:
And here are two shots after I fixed it. You can see the grind on crossmember bracket and also how much the weld was taken down. This is enough room to keep it from rattling and banging around:
Old Jan 6, 2005 | 09:39 PM
  #34
Thanks for the pics snakeoiler, when I get it back up on the lift Ill check the clearance out.
Old Jan 7, 2005 | 12:26 AM
  #35
Munson's Avatar
damn thats a badass camera that thing takes some close up pics
zblee
63
Jun 10, 2023 01:25 PM
USMCvet0311
Aug 13, 2015 09:59 PM
black03rcsb
13
Aug 13, 2015 04:05 PM
mrhino
Aug 7, 2015 10:01 AM
zblee
Aug 3, 2015 03:45 AM
