Helicoil a sparkplug hole?
Old Dec 20, 2007 | 07:39 PM
dlt76028's Avatar
Default Helicoil a sparkplug hole?
Should I? When I put my headers on I noticed my front spark plug didnt look like the others and it was just forced in and stripped and I tried and tried but couldnt get it to go it correctly. now I have a bad ticking/leak and I opened the hood today and the spark plug and wire were shaking and it had worked its way out alot and was real loose? has anyone had this problem? and where should I get a helicoil kit and what size? thanks
Old Dec 20, 2007 | 07:44 PM
I had a similar issue with my spark plugs in some new heads. You should search my name for the threads. I was recommended by a few professionals and people on here not to because the aluminum doesn't bind as well with the helicoil and the high pressure in the cylinder heads could lead to more problems.
Old Dec 21, 2007 | 09:59 AM
vanillagorilla's Avatar
Try one of these: http://www.back-tap.com/
Old Dec 21, 2007 | 10:11 AM
dlt76028's Avatar
That looks like exactlly what I need, I dont know about that $80 though
Old Dec 21, 2007 | 10:14 AM
Tootall's Avatar
they make kits just for things like that . . . and they seal off just like stock
Old Dec 21, 2007 | 04:54 PM
80 dollars is a lot cheaper than a new head.
Old Dec 21, 2007 | 05:46 PM
kingots2004's Avatar
what head is this?what size motor i got some heads.
Old Dec 21, 2007 | 09:10 PM
dlt76028's Avatar
It's a 4.8 #862. I ran a thread chaser in the hole it's tight now and looks about the right angle but it's still ticking...
Old Dec 22, 2007 | 06:24 PM
sixltrbtr's Avatar
I had the same problem with my truck. I bought a kit made by Helicoil at the local parts store. It came with a special tap and 3 sleeves of different lengths. I put in the longest one (it matched the plug) and haven't had a problem. It's been that way for a couple of years now. I wouldn't run one on a performance engine though. I don't remember the cost but it was a lot cheaper than $80. If you have the time and money I would get a good used head and replace it. http://www.globalspec.com/FeaturedPr..._x_125/23773/0
Old Dec 22, 2007 | 07:14 PM
dlt76028's Avatar
Thanks i'm going to check autozone and orielys
