Helicoil a sparkplug hole?
Old Dec 23, 2007 | 08:00 AM
TG02Z71's Avatar
If you chased the threads with the appropriate tap you should be ok. Try rotating the spark plud CCW until you feel it fall into the start of the first thread, then go CW very slowly. This is a trick used on fine pitch threads.
Maybe add a slight amount of anti-seize to keep it from galling the existing threads worse.
Be carefull and good luck
Old Dec 23, 2007 | 06:23 PM
I the threads are FUBAR then chasing it is just going to cut them up even worse. Any route you choose, be careful using your existing threads or helicoil. If that fails, time and $$ are going to go way up.
walledition
Feb 24, 2026 03:27 PM
Chavette
Oct 28, 2015 07:33 PM
726.0chevelle
Sep 12, 2015 09:24 AM
tgui
Aug 15, 2015 12:27 PM
