Gauge install question
Old Jun 2, 2005 | 10:00 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Gauge install question
What is the difference in electrical guages and mechanical ones? I am looking to add a trans temp and fuel pressure gauge to my pod which already has a Magnuson boost gauge. The boost gauge works great but I didn't install it so I'm not sure what type it is. How do I find out which one I need?
Old Jun 2, 2005 | 10:13 PM
1SlowHoe's Avatar
Might have answered my own question with a little research, but still not sure if I'm right. Mechanical requires (say for the fuel pressure) the fuel line to actually be run into and out of the gauge to get a reading, meaning I can't install it in the pillar in the truck cab. An electrical uses sending units to measure the pressure and sends the signal to the guage meaning I can mount in the cab. Am I Close?
Old Jun 2, 2005 | 10:40 PM
ThunderZ28's Avatar
12 Second Club
yes..
your on the right path.
electrical gauges use a sending wire. as you stated..
and the mechanical guages require some sort of pressure..(whether it be air or liquid) to read. as for your truck you should be good with the electric guage.
you may need to do some research as to what wire to splice into.
Old Jun 2, 2005 | 10:43 PM
1SlowHoe's Avatar
The electrical fuel pressure gauge is 190 bucks. I was trying to get away with not spending that much. The tranny temp gauge is only 50 bucks (electrical) Oh well, guess I have to pay for my toys
Old Jun 3, 2005 | 02:28 AM
thunder550's Avatar
High on diesel fumes
You would be much better off to avoid running fluid lines into the cab...especially fuel. Definitely stay away from mechanical if you are putting the gauges inside.
I am running electric fuel pressure and tranny temp gauges, and a mechanical boost gauge. My autometer fuel pressure sender threaded right into the pressure port thingy on the driver's side fuel rail, very easy install.
Old Jun 3, 2005 | 06:57 AM
1SlowHoe's Avatar
Doesn't sound too hard, and thanks for the pic!
Old Jun 3, 2005 | 09:22 AM
thunder550's Avatar
No prob, hope it helps!
Old Dec 4, 2005 | 12:47 PM
BLASTER's Avatar
sorry to resurrecct an old thread but I will be doing this soon. Just ordered my Radix and want to get a C2 fuel pressure guage.
Thunder550, looks like you just hooked into the radix fuel rail? Is there a fitting for this on the fuel rail or did you have to do some modifing drilling/tapping/ets. Basically I am trying to figure out if I need to buy any extra adapters or anything before I install.
Thanks
thunder550
Oct 8, 2015 04:53 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
