Electric fans
Old Jan 10, 2011 | 06:21 PM
Mangled03gmc's Avatar
Baltimore Whore
No mine came in great shape..The fans will fit about perfect behind your radiator.. You set them so they rest on the core support. Now I know alot of guys say that these( pic added) will cause leaks.. If they are not installed proper, I would agree they might.. But it is kinda hard for a plastic line to break a metal tube.. Anyway if you do it, get some good sticky side industrial weather strip(foam) cut pieces that cover the corners of the fan shroud.. Then put them tabs through the rad, the shroud. Pull them in snug, do not over do it. 2 years of daily driving, a few 130mph blast, a ton of 110-120 mph runs, NOT A SINGLE PROB. I think it is a cleaner install then the brackets people make, looks about as factory as you can get. Now if you want to look factor oem, buy a 34'' rad, the fans from a 05 up truck...
Old Jan 10, 2011 | 07:07 PM
1blueSS's Avatar
formerly 1fstrst (11/25/2010)
I got my ls1 fans from a member on here. I paid $160ish for the fans with the harness (nelson i think). good deal now I just need to find the time to install them.
Old Jan 10, 2011 | 07:16 PM
loloone's Avatar
LS1Tech Editor
Any of you guys with LS1 fans found them insufficient? I know some people claim they're too small. At least that's what I've found in searching around on here.
Thanks!
Old Jan 10, 2011 | 07:23 PM
Baltimore Whore
Thanks!
I have never over heated ever.. It's has warmed up 1 time on me to about 230, when I was sitting in traffic, like STOPPED on a 110 deg day for 45mn or so.. Now for the kicker, that was with only 1 fan hooked up.. So what I am saying is they are more then enough
Old Jan 11, 2011 | 08:36 AM
too slow's Avatar
Sweet thanks.
SS94S10
Jan 3, 2019 01:57 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
