de-crank or drop spindle
my keys are cranked up to level the front
if i want to drop the to lower the the REAR and and drop the FRONT can i achieve this by getting a drop lowering SPINDLE and a drop shackle for the rear
OR DO I HAVE TO RETURN TRUCKS STOCK HEIGHT BEFORE CHANGING THINGS?
If you have an old junky c-clamp, if you remove the swivel foot from it or if you’re lucky and already have one that’s missing, it works good as the ball end will fit better in the dimple that’s on the bottom side of the keys, where it will be less likely to slip off. Whatever you do work slow and be careful. Also, make sure to lift the weight up off the wheels before cranking around on the bolts, so not as to stress them.
