Damb just broke a front wheel stud...
Old Nov 1, 2008 | 10:41 AM
phasemaster1's Avatar
Default Damb just broke a front wheel stud...
How much of a pain is it to install new one. Truck is 2003 2wd.
Old Nov 1, 2008 | 07:45 PM
dlt76028's Avatar
i got a broke one too. i heard its not bad just hit the old one out and put the new one in and put a lug on it and tighten it down and it will pull itself out. haven't done it yet so not positive thats right?
Old Nov 1, 2008 | 07:48 PM
RandomHero's Avatar
I've never heard of doing that, but you can buy a full replacement hub for about $80-90 shipped.
Old Nov 1, 2008 | 09:31 PM
Truckshop's Avatar
lug studs are about 5 bucks. knock the old one out and pull the new one in with a lug nut as stated. easy as changing your brakes.
Old Nov 1, 2008 | 10:17 PM
alanderson1978's Avatar
I went through a bunch of them on my old Sebring. Just like the others said, bang it out, stick the new one in. The lug pulls it tight in back. An air hammer may help out depending on how hard it is stuck in there.
Old Nov 2, 2008 | 07:04 AM
well Ive done it in the back once before but havent even looked at what needs to be removed in the front. Truck still has 97,xxx miles so didnt want to replace the hub yet and when I do Ill replace both so it will be about $200. Thanks
Old Nov 2, 2008 | 07:17 AM
ChevyTruck's Avatar
something else
If you do it that way use a nut that is bigger then the stud and smaller then the lug nut. use that "space nut" to help set the stud all the way, you dont want to leave the stud sticking out behind the hub at all.
That is just my .02 cents, I worked at a rim and tire shop for 2 years thats why I am saying that.
Good luck.
Old Nov 2, 2008 | 11:27 AM
dlt76028's Avatar
Good luck.
yea i heard that you have to do that. someone told me you could use the rotor...
Old Nov 2, 2008 | 05:14 PM
MonteCarlo31's Avatar
is the back one hard to do on a 06 w/ rear drums? I've got the same problem, infact I forgot about it when I was pulling my blown monte this weekend (uhhhhh...) but I figure 5 lugs is still good.
Old Nov 2, 2008 | 07:54 PM
budhayes3's Avatar
PT's Slowest Truck
It's even easier than the front since you don't have to pull apart a caliper, brake pads and bracket, and rotor. Just remove the drum, hammer the busted stud out and use a lug nut to run the new stud on. I usually flip the lug nut and use a few thick washers if necessary
BoostedBowTie
Jan 3, 2020 06:46 PM
Steve-O-08
Apr 19, 2018 09:32 AM
Corvette454l88
Sep 1, 2016 01:24 AM
ss454327
Oct 17, 2015 03:43 PM
mrgrim
Jul 8, 2015 08:12 AM
