Catch Can Recommendation
Old May 19, 2018 | 07:35 PM
darkirish63's Avatar
Originally Posted by PFIX
Looking in to a catch can for my 01 Silverado 6.0 N.A motor. Wanting opinions on what can to purchase and I am also wondering about oil and fuel odors after installing a catch can, I am hearing some comments about strong odors after installing.
Used to run a Norris can but didn't like the drain or filtering. Running a Mighty Mouse now...awesome.
Old May 19, 2018 | 09:00 PM
bigsapper's Avatar
Mighty Mouse
Old May 20, 2018 | 11:11 AM
Originally Posted by Jonblarc7
Where does the check valve go. I got 170K on the clock and need to get a catch can on there. I guess I'm alittle behind LOL
If your motor has the built in PCV in the driver's side valve cover you don't need one. If using after market covers like the Holley LS covers then it goes between the cover and the can.
Old May 21, 2018 | 08:12 AM
Choda's Avatar
Any reason you went away from the Norris can for the RX? Did the Norris can work well?
Norris can did work but it was only the can and it was pretty small. I went with the RX monster because I wanted a bigger can and a full system ( Clean air separator ). I have also never seen a video comparing Norris to other cans, were this RX monster can was compared to Moroso with 2K mile test and ended up catching ounces of junk that the moroso did not. The guy ran them in line and that pretty much sold me on it.
Yup, $400 was a a lot for a catch can but I plan on keeping it for the life of the truck. My dual valve also supports Boosted and NA setups.
Old May 21, 2018 | 11:46 AM
BudRacing's Avatar
The check valve I referenced is for the fresh air inlet side (to the PS valve cover up front) to make sure that nothing gets pushed back into the throttle body primarily during decel--more relevant for a manual trans, though. It prevents any mayo looking deposits from creeping. It happens.
Example of check valve placement on an LS6.
05crew
Nov 15, 2009 01:59 PM
bootleg
33
Nov 14, 2005 12:19 AM
BLASTER
22
Jun 22, 2004 08:38 PM
MacADaYear
16
May 3, 2004 09:26 AM
Lee Stroud
Oct 11, 2002 10:41 PM
