Cannot power brake to launch????
Old Feb 1, 2006 | 06:12 PM
JOHN1L40's Avatar
Default Cannot power brake to launch????
Is there something in the PCM that limits power when the brake is on or when you are not moving? I try and power brake and I have no power. It will not try and build rpms or even strain the brakes. As soon as I start rolling I have a rush of power??
Old Feb 1, 2006 | 06:26 PM
Mort's Avatar
Cool
I am not sure why you are having a problem. My truck will stall up to about 2500 rpm and yours should as well. If I hold it at part throttle opening I have seen over 4 psi of boost before launching at 2500 rpm. I would ask Allen if he can help you out with this. If it is in the tune I am sure he will be able to help you out. I think that something is wrong with your tune or throttle linkage and I hope someone can help you out with it.
Good luck
Old Feb 1, 2006 | 07:13 PM
TIM Z's Avatar
11 sec. Truck Mod
i think it probably is in your tune, mine did the same thing and allen worked with me to correct it, but since ive got the intercooler my truck really came to life and will roast the tires into oblivion at 6#s of boost, you need to get some values for him to help dial in your tune- L-trims at steady speed, I.A.T.s and timing at W.O.T . ,Knock Retard at W.o.t. and O2s should be around 920mv. im sorry to post if you already know this, just some thoughts on your prob, good luck!
Old Feb 1, 2006 | 07:58 PM
Scott Mills's Avatar
Mine does the same thing. It just bogs down and wont build rpm's.
Old Feb 1, 2006 | 08:37 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I read somewhere (on this site) that GM was working on programming to do exactly what your describing. As you build rpm but don't register tire spin (brake stalling) the PCM pulls timing. I would think it can be tuned out but I was under the impression it wasn't in the PCM's yet. I thought it was coming in 06+ but maybe they snuck it in early.
Old Feb 1, 2006 | 08:47 PM
quicksilverado's Avatar
I don't see a stall in your sig. Without one it will not build any boost because the stock converter will not let the motor rev high enough.
Old Feb 1, 2006 | 09:10 PM
DrX's Avatar
DrX
The electronic throttle control(ETC) vehicles have "Brake Torque Management"(BTM) which will limit throttle opening if your foot is on the brake. This can be disabled in the tune.
Old Feb 3, 2006 | 04:34 AM
dkubricht's Avatar
so does that mean I cant power brake too? does that also mean I cant do a burnout?
Old Feb 3, 2006 | 08:25 AM
DrX's Avatar
DrX
There are also several other "Torque Management" and "Abuse Management" parameters in the factory calibration that limit power output under various conditions. WOT launches would be one of those conditions.
Old Feb 3, 2006 | 08:52 AM
Beastofa327's Avatar
Mine is still stock no tune only mod is exhaust. I've never had a problem. What I do is apply brake softly apply gas as the back tires have forward momentum apply alot more pressure the the brakes and you'll be smoking'em too.
Corvette454l88
Sep 1, 2016 01:24 AM
dry_kill
11
Aug 28, 2015 09:53 PM
fastjweb
Aug 15, 2015 10:47 AM
1320Chicken
Jul 14, 2015 10:58 PM
