Budget build. Like really low
Old Oct 19, 2014 | 07:10 PM
  #31
Leegreens's Avatar
Cleaned up front some more. No AC, cut the hinge off put on pin kit.
Had to give it a project name.
Old Oct 26, 2014 | 10:55 PM
  #32
Offroadunleashed's Avatar
That has got to be the best project name EVER!
Old Oct 27, 2014 | 04:39 AM
  #33
Leegreens's Avatar
Default Best ever
Heres a sticker i had made for a 4cyl 91 dakota i used to winter beat on.
Just order headers & y-pipe.
Now i need to research best nitrous cam, only thing else i would want w the cam is a nice custom rough idle so i can ran the electric cut out at tge gas station. I like Loud & obnoxious
Old Oct 28, 2014 | 08:49 PM
  #34
Leegreens's Avatar
My drive shaft was jacked $300 to get new carrier & high speed balance. Lots of dents & ears bent. Had HD u-joints put in also.
Old Nov 2, 2014 | 06:56 AM
  #35
Leegreens's Avatar
Default More parts
Pacesetter long tubes added w Y-pipe. Going to run 3" electric cutout & 3 1/2 exhaust w that size magnaflow race bullet.
Dumped before axle or out the bed side?
Old Nov 2, 2014 | 06:59 AM
  #36
Leegreens's Avatar
Should i run a h or x-pipe?
I just purchased from a member a vigilante 3200 stall cheap.
Who's nitrous cam should i go with?
I was going to take it to nelsons for tuning but i know they are turbo ppl. Who's big w the spray tunes?
Old Nov 6, 2014 | 09:19 AM
  #37
Leegreens's Avatar
Default Water pump
I want to also run an electric water pump.
Anyone have links to a budget type setup. Theres no budget required for this but i dont want to buy the nice street meziere.
Old Nov 7, 2014 | 03:00 PM
  #38
Jackal1's Avatar
i've always ran off road y pipe 3 in the whole way, works and sounds amazing...never tried an x on these trucks, and i would just stray away from the H
Old Nov 13, 2014 | 10:36 AM
  #39
Leegreens's Avatar
Ok i'm going to go 3 1/2 after the electric cut out & just run the off road pipe how it all is.
Side pipe it to make it easy but i'll hack some more & make it come out the qaurter panel.
Old Dec 10, 2014 | 09:29 PM
  #40
Leegreens's Avatar
Added my used cia from a member. Had to make a gasket between air box & filter where mounts to MAS. Something was missing. Some soft pipe insulator worked.
Now will this CAI work better if i make a lid for this air box & cut out the plastic for the headlights thats really not structurally needed? Was thinking about doing that.
