Bed Creaking
Old May 6, 2010 | 01:23 AM
2001CamaroGuy's Avatar
Default Bed Creaking
Ever since I did the 4 link/ rear airbag conversion, I have been noticing more and more creaking out of the bed area. Best I can tell, there must be movement at the mount points between the frame and the bed. Tomorrow I'm going to get under the truck and hit the bolts with an impact wrench to tighten them up to see if that helps.
I'm posting this though to see if anyone else has experienced creaking out of their truck. My truck has 125K mile on it.
Side questions: How does one remove the rubber vibration isolators between the body and the frame? I would like to remove and replace them with solid (I would machine up aluminum) spacers to get rid of flex here.
Old May 6, 2010 | 08:29 PM
I checked the 6 bolts on the truck with an impact wrench. 4 of the 6 bolts were TIGHT (didn't budge a bit) and 2 only turned about 3/4 of a turn tighter. I also removed the frame-to-cab straps that everyone complains about. The creaking seems reduced, but still there. Any ideas?
Still wondering about the rubber isolators. Anyone know how these come off?
Old May 28, 2010 | 01:42 AM
ttt..... come on people...if this was a "help my pick my cam", there would be 10 pages of replies
Old May 28, 2010 | 08:14 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
my bed creaks too
lol, sorry, couldn't resist. I can't answer your question but in my research of 4-link setups I have heard that increased noise is common?
Old May 28, 2010 | 10:48 AM
It is, but that noise is from road transmission into the frame and in some cases (in the event you use cheep rod end) rod ends pounding. This is actually in the bed/frame. I can get on the bumper and jump up and down causing creaking.
Old May 28, 2010 | 05:07 PM
MikeGyver's Avatar
If you have not yet, lay underneath and get someone else to jump on it for you.
Old May 28, 2010 | 05:45 PM
Have done that already. It seems like the noise is coming from the bed-to-frame mounts. The noise is far from shocks/springs/4-link rod ends/any suspension parts.
Oddest thing is it comes and goes. Seems nosiest with temp extremes (ie: hot/middle of the day or cold/night time).
Old May 29, 2010 | 12:19 PM
842ta's Avatar
Mabe get some WD40 and hit the bushings on the bed mounts
Old May 30, 2010 | 04:01 PM
03 BLACKOUTSSS's Avatar
I am playing the same game right now, except i have no idea where mine is coming from. I think I have a shock going bad. Who knows.
AdaMax
May 16, 2016 11:35 PM
jscherbs
Sep 30, 2015 07:54 AM
tim wellington
Sep 29, 2015 10:17 PM
old motorhead
Sep 29, 2015 08:22 PM
Slammed silverado
Sep 28, 2015 06:14 PM
