4 gauge neg. cable
Old Jul 9, 2008 | 11:12 PM
Default 4 gauge neg. cable
Been searching and can't find where to buy a 4 gauge negative battery cable for my truck, help.
Old Jul 9, 2008 | 11:13 PM
53bowtie's Avatar
grab some 4 ga. off the bay and make your own....
Old Jul 9, 2008 | 11:18 PM
Kinda wanted to keep the factory looking cap at the battery. Maybe that isn't possible?
Old Jul 9, 2008 | 11:24 PM
Stoichiometric's Avatar
Try posting in the GM part number thread
https://www.performancetrucks.net/fo...gm+part+number
Old Jul 9, 2008 | 11:31 PM
53bowtie's Avatar
I suppose you could buy the cable from GM but i think it is rather expensive. I just replaced the positive cable on a 3800 mailbu at my dads shop and i want to say it was around the $100 just for the cable......
Old Jul 11, 2008 | 12:07 PM
oldred95's Avatar
Go to a welding shop. They should have anything from 4 gauge to double ought(sp) gauge. I upgraded my cables to double ought which I got for free. My dad and I work on tractors and depending on the one they might use a cable anywhere from 6 inches to 12 feet long and are prone to wearing through. I just cut a good section out of the old cables and use it where I need it. For terminals I use brass solder on cable lugs. You can get them at a welding shop as well. Always always solder. Never crimp.
And yes an OEM cable will be rediculously expensive.
Old Jul 13, 2008 | 11:31 PM
shandy294's Avatar
What's "brass solder". I've only heard of resin and acid core solder.
Old Jul 13, 2008 | 11:34 PM
rclnc's Avatar
You may want to try a diesel truck parts store.
Old Jul 14, 2008 | 02:23 AM
eallanboggs's Avatar
He doesn't mean the solder is brass. The terminal is brass. You can go to a good home supply or hardware store for this wire(Lowe's, Home Depot,Ace). It expensive, but no where near $100.00. Get large brass terminals and as was already recommended solder them. Be SURE you make a good solder joint. Don't heat the solder. With 4 gauge wire and large, thick terminals you'll need a lot of heat before the solder will flow. Heat the terminal and wire thoroughly before applying the solder. When properly heated the solder should flow and be shiny when in a molten state. Don't skimp on the solder. You need not only a good electrical bond, but a good mechanical one as well. You might want to put the wire in a vise with a shop rag wrapped around it to hold it in the proper position for soldering.
Old Jul 14, 2008 | 11:22 PM
shandy294's Avatar
I see...brass solder-on lugs...
Texas5.3_1251
Mar 5, 2016 08:10 PM
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
zblee
Sep 17, 2015 07:58 AM
kmcn47
Sep 17, 2015 01:12 AM
