EPS 218/222 3 bolt cam
Old Sep 1, 2011 | 07:57 PM
iamkeniff's Avatar
Default EPS 218/222 3 bolt cam
218/222 .595/.596 114+4
This is out of SkoalBandit's 5.3 worked very well and i think has 6500-7000 miles on it. I could be wrong but i know it doesnt have a lot of miles on it
3 bolt cam
335 shipped obo
Pics will be up asap
Old Sep 1, 2011 | 08:08 PM
whitedakota's Avatar
would that work decent in my truck with my mods in sig? or will the "3 bolt" not work for my year? thanks
Old Sep 1, 2011 | 08:23 PM
midevil1's Avatar
Your truck has a 3 bolt cam in it.
Old Sep 1, 2011 | 08:26 PM
ok appricate it midevil1. never hurts to ask i guess.
Old Sep 1, 2011 | 08:38 PM
iamkeniff's Avatar
Yeah it'll work in your truck...you will need a .600+ lift spring
Old Sep 1, 2011 | 11:19 PM
devink's Avatar
How would this cam behave in comparison to a tr220?
Old Sep 2, 2011 | 04:19 AM
iamkeniff's Avatar
Its hard to say. It comes down to your choice of gears and converter. Plus how many rpms you are going to spin it to.
This cam wont require a ton of converter...it'll work well with 3:42s all the way to 4:56s if you want to go that extreme. Also the cam comes in strong about 2200-2500 rpms so you can use a 2500-3200 converter and itll work well.
Skoalbandit ran it in a CC with a 278mm circle d 3000 converter with 3:73s and 20" rims. I think he shifted it out at 6300 and it pulled the entire rpm.
Old Sep 2, 2011 | 08:36 AM
devink's Avatar
One more question you may or may not be able to answer: every couple years I need to pull my headers and PCM for smog testing (Kalifornia ). Do you think I'd still be able to pass a sniffer test with everything else returned to stock?
Old Sep 2, 2011 | 09:19 AM
midevil1's Avatar
With the LSA that is ground into that cam and the low duration. You would have a good chance of passing. I would lean it out in the 2000 to 3500 rpm range to make sure.
Old Sep 2, 2011 | 10:53 AM
BBchevelle's Avatar
any sound clips?
