Z06 cam install on a 5.3 ?
Old Jan 24, 2008 | 06:10 PM
sharpshooter's Avatar
Default Z06 cam install on a 5.3 ?
If I install a 2004 Z06 cam and Z06 springs on a my 5.3 should I run the Z06 push rods or use my stock ones?
Are 04 Z06 cams the same specs as the 02 Z06 cams?
Old Jan 24, 2008 | 06:14 PM
AJK381's Avatar
Im using stock pushrods, been about 3k with no problems. i know af a few other people that have done the same, i have a 02 cam in mine.
Old Jan 24, 2008 | 06:18 PM
xlcooplx's Avatar
Aren't the Z06 cams ground on a smaller base circle? I'd run the Z06 rods at minimum
Old Jan 24, 2008 | 06:25 PM
So the Z06 rods are longer than ours?
Old Jan 24, 2008 | 07:28 PM
xlcooplx's Avatar
If indeed the base-circle of the Z06 cam is smaller, then I would think so unless GM did something else to compensate for the smaller base-circle.
Old Jan 24, 2008 | 08:30 PM
PathfinderJr's Avatar
I could be wrong, but I think the valve stem is longer on the LS6 to compensate for the smaller base circle.
Old Jan 25, 2008 | 12:17 AM
jakebdb56's Avatar
the Z-06's base circle is smaller, I believe the correct pushrod length is 7.425"
Old Jan 25, 2008 | 12:44 AM
kbracing96's Avatar
This correct, the base circle is .050 smaller, but there is enough travel in our stock lifters to make up the difference. The Z06 push rods and our rods are the same, and you can reuse you stock rods and it WILL work fine. I have personally done it as well as others on this board. It you feel more conferable, you can get 7.425 rods to keep the lifters at there factory preload level, but they are not required.
Old Jan 25, 2008 | 12:51 AM
blue 01's Avatar
Dam KB you must type faster than me.
No both 7.4
02 to 04 z06 has a.050 smaller base dia. You can run your stock length (7.4 )or buy some (7.425). The lifter only see .025 of the .05. Lots of people here have ran there stock rod with out problems. If you are going to buy harden rods go ahead and get 7.425
As PathfinderJr said the valve stem is longer on the LS6 to compensate for the smaller base circle
Choda
Jan 22, 2026 02:03 PM
5.3Okasai
Mar 9, 2022 01:07 PM
all_individual
Oct 10, 2015 10:09 PM
steves86ta
Jul 28, 2015 10:21 AM
all_individual
Jul 13, 2015 11:01 AM
