Yukon 6.2, long tube headers installed, help please
Old May 20, 2018 | 07:34 PM
tgui's Avatar
Default Yukon 6.2, long tube headers installed, help please
I installed Speed Engineering 1 7/8'' long tube headers. Great price, fast delivery but I am having a couple of issues.
1) Drivers O2 sensor hits the body when the engine is under load. What do?
- I dropped the header down as low as it could go.
- Drivers engine mount is new, passengers is old. Should I replace the passengers? How can I keep the engine from moving around so much
- I trimmed the O2 sensor which helped a little. Stupid if it works?
- I've stared cutting a hole where the below red arrow points. How best do I cut out enough? Is this the right path?
- Should I have another O2 bung welded in at another angle? (pain in the ***, but will do if needed).
2) I have no cats, stock muffler and resonator delete. How do I quiet this down? Holy **** this is loud and sounds crappy.
- Should I add a cat after the ypipe to quiet things down? I'm planning to do so also for the smell.
- Suggestions on mufflers or other ways to make my neighbors and wife love me again?
O2 Sensor hits here. Its double walled steel where I used a large drill bit to cut space for the sensor. I didn't cut enough.
Trimmed O2 sensor. I can at least drive normally without hitting. I used a dremel.
Another view of the sensor.
Just a quick vid. Not captured the holy ***** nascar sounds at full tilt.
Body shot.
Thanks!
Old May 20, 2018 | 08:00 PM
FFDP's Avatar
Add a nice resonator back in, that should tone down the rasp a ton when using the stock muffler. That or a decent sized cat will act as a nice resonator in most cases.
I wouldn't cut a hole but more so just pound the body in with a hammer to make more clearance for the o2 sensor.
Old May 20, 2018 | 08:06 PM
tgui's Avatar
I was thinking about putting the stock resonator back on. I'll try that AND a cat.
I wonder if pounding things in would be enough? Cant hurt to try though I don't have a lift.
Think I could do it on my back?
Old May 20, 2018 | 08:16 PM
10 Second Club
https://www.youtube.com/watch?v=SbxXTWOxRhs
Body shot.
Thanks!
Sounds bad *** for a stock muffler. I run two Dynomax race bullets ahead of the Magnaflow muffler on my truck. Very tame at cruise and idle.
Old May 20, 2018 | 08:40 PM
tgui's Avatar
Dude, its so damn loud lol. Thanks for the bullets and magnaflow ideas.
Old May 21, 2018 | 06:56 AM
MikeGyver's Avatar
That's what I did.
Old May 21, 2018 | 09:56 AM
dantheman1540's Avatar
I've got long tubes with a vibrant ultra quiet resonator and stock muffler off a NNBS with a 6.2 and it's completely silent. I would suggest a vibrant ultra quiet resonator right after the header collector.
Old May 21, 2018 | 10:58 AM
tgui's Avatar
Do you have cats?
Old May 21, 2018 | 11:24 AM
No cats just long tubes to a single 3in vibrant ultra quiet and then back to a 3in NNBS muffler.
Old May 21, 2018 | 01:23 PM
tgui's Avatar
Originally Posted by MikeGyver
That's what I did.
Dumb question. What kind of hammer? Like regular hand held. Sledgehammer? I've never hammered in body parts before.
