will running a smaller crank pulley have any effect on S/C boost?
Old May 5, 2004 | 05:10 PM
moregrip's Avatar
what a rush!
Default will running a smaller crank pulley have any effect on S/C boost?
lets say someone had a radix designed to run at 6-7psi boost
would running a smaller crank pulley increase said boost?
Old May 5, 2004 | 05:15 PM
TwoFast's Avatar
You will loose boost. Hopefully Blownchevy can chime in soon. He can tell you all about it.
Old May 5, 2004 | 05:21 PM
moregrip's Avatar
what a rush!
now that I think about it more I think that is correct
my analogy is this:
on a motorcycle if you want to have lower overall gear selections without going into the tranny you have two options......install a smaller front sprocket(i.e. blower pulley) or a larger rear sprocket (i.e. crank pulley)
makes perfect sense know! what was I thinking?
Old May 5, 2004 | 05:25 PM
BlownChevy's Avatar
blownerator
25 Year Member
Chime!
Smaller pulley, less boost. Bigger Pulley more boost!
Deckhand's Avatar
my analogy is this:
must be those women!
Old May 5, 2004 | 05:27 PM
yeary03SS's Avatar
This may sound strange, but you'll have to have a bigger crank pulley to increase boost. The crankshaft will always spin at the same rotational speed. On two pulleys connected by a belt, the angular velocity times the radius of one pulley must equal the angular velocity times the radius of the second one. Thus keeping the same angular velocity on the crank and using a bigger radius makes the angular velocity increase on the unchanged radius on the supercharger pulley. Going to a smaller pulley on the supercharger itself will also increase boost.
Old May 5, 2004 | 06:02 PM
BlownChevy's Avatar
blownerator
25 Year Member
Uhhhhh, uhhhhhh huh huhuhuhuhhh he said bigger radius.
Old May 6, 2004 | 06:04 AM
yeary03SS's Avatar
yeah, yeah, bigger radius (that was my attempt at Beavis)
stealthperf
34
Feb 14, 2016 11:35 AM
TAPyvehc93
Aug 21, 2015 05:19 AM
bigsapper
Jul 28, 2015 12:56 AM
blownss27
Jul 20, 2015 08:59 AM
bsn1989
Jul 16, 2015 08:20 AM
