Will the 8.1 injectors plug right into the ....
Old Jun 18, 2007 | 09:35 PM
Stampede4ever's Avatar
Default Will the 8.1 injectors plug right into the ....
wiring harness, and fuel rails?
Thanks.
Old Jun 18, 2007 | 09:48 PM
cpelton's Avatar
yes! direct easy replacement.
Old Jun 18, 2007 | 09:49 PM
truckmann's Avatar
^^^ what he said.
Derek @ EDO's Avatar
FormerVendor
Old Jun 18, 2007 | 09:55 PM
rivierakid55's Avatar
they will be wont run worth a chit without a tune.
Old Jun 18, 2007 | 09:58 PM
ChevyThunder17's Avatar
Yes, that's kind of an important little factoid. While they are physically a plug and play install, without tuning it's going to dump twice as much fuel (literally) as it would normally.
Old Jun 18, 2007 | 10:14 PM
99Silverado5.3's Avatar
Direct replacement and you will need a retune. Also, you will be able to drive with them if you need to.
Old Jun 18, 2007 | 10:15 PM
Say hello to uber negative fuel trims. I'd be afraid of hydrolocking the engine on fuel.
Old Jun 19, 2007 | 08:24 AM
skyhighsami's Avatar
no title here
Why in the world would you need injectors that can push twice the amount of fuel without F/I or a hella motor?
Old Jun 19, 2007 | 08:34 AM
Because the stock injectors become maxxed with a decent cam and exhaust mods. If you can score a set of the 8.1 Marine injectors, it's worth it. You're better off with more injector than not enough.
