Will the 8.1 injectors plug right into the ....
Old Jun 19, 2007 | 12:39 PM
  #21
Mark Johnson's Avatar
Originally Posted by ChevyThunder17
Technically speaking, yes they would. They'd allow you to run the extra fuel required (about 40%) without maxxing out the IDC.
Still kind of a newb- what's the IDC.............
Old Jun 19, 2007 | 12:43 PM
  #22
RandomHero's Avatar
Injector Duty cycle-A number(in the form of a percentage) that shows how much flow your injectors are performing.
So your IDC was at 50%. You'd only be using half of what your injectors max out at.
Old Jun 19, 2007 | 12:48 PM
  #23
ChevyThunder17's Avatar
Generally speaking if your Injector Duty Cycle is over 90%, you want to get bigger injectors.
Old Jun 20, 2007 | 11:24 AM
  #24
Alright- thanks for the info, guys. As to my question about the 8.1 injectors and converting to an Ethanol tune. Is there a better injector for that purpose......
Old Jun 20, 2007 | 11:47 AM
  #25
1FUNZ71's Avatar
14 Second Truck Club
I am hitting 103% with being pretty much stock, Injectors are next before I doing anything else.
Old Jun 20, 2007 | 11:22 PM
  #26
1FUNZ71's Avatar
Are Venom injectors any good?
Old Jun 21, 2007 | 08:16 AM
  #27
Silver-Dollar's Avatar
After doing some research, I think 42# might be overkill. A naturally aspirated 400hp engine rating at 80% IDC should require 32# injectors.
I will now more when I actually have the engine in and the tuner is looking at IDC. Not going to purchase anything until this happens.
Old Jun 22, 2007 | 08:42 AM
  #28
Grumpy5.3's Avatar
http://cgi.ebay.com/ebaymotors/Chevy...em110140195415
Are these the injectors everyone is talking about???? $125 isnt bad, b/c my cost here at a dealer is $80.00 a piece!!!!
Old Jun 22, 2007 | 09:45 AM
  #29
On trucks and SUVs, were the stock injectors the short ones, aka mini? Is the only direct higher flow replacement Delphi 8.1 marine injectors at 42#? I have searching my *** off and can only find the Delphi 42# listed as a replacement.
On-line calculators come up with 36#. I believe 42# may be overkill. But if they are the only replacement that does not require fuel rail modification, then I guess that is what I need to get.
Again this will be on a truck style intake/fuel rail for LQ9 swap.
Old Jun 22, 2007 | 09:55 AM
  #30
ap2002's Avatar
when I first installed my cammed LQ9, my IDC was @ 95% without the nitrous, so I had to go with some 42lbers for the nitrous,
I dont think there is such thing as an overkill on the injectors, what if you decide to spray it later on? you wont have to worry about injectors anymore... check the classifieds, you can get them there for about $250...
