waterpump option for fast or ls6 intake?
Old Sep 14, 2009 | 08:06 PM
fastrt's Avatar
11 Second Truck Club
Default waterpump option for fast or ls6 intake?
have any of you guys run one of these waterpumps for a ls6swap or fast intake swap?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
looks like it is a car pump with a truck pulley from ac delco. i bought one just in case I run a fast on my new motor build.
Mangled03gmc's Avatar
Baltimore Whore
All you need is a late model truck pump with the water neck that points out instead of up..
Old Sep 14, 2009 | 08:10 PM
fastrt's Avatar
I still hear that they have clearance issues. but you never know till you try right?
Old Sep 14, 2009 | 09:10 PM
2001CamaroGuy's Avatar
That's nothing more than an f-body/Vette pump. The truck pulley remember has the place for a manual fan.
Just get a used, low mileage LS1 f-body/Vette pump off ls1tech, ebay, or craigslist. I'm using the stock pump off my Camaro which had 50K miles before being put on the truck and since has had 125K more put on it. Still going strong.
Old Sep 14, 2009 | 09:28 PM
bluecajun5.3's Avatar
that will only work with a cable style tb, not dbw...
Old Sep 14, 2009 | 09:30 PM
Baltimore Whore
Ahh yes.. My bad...
Old Sep 14, 2009 | 09:35 PM
00ChevyScott's Avatar
Wearin' da big hat
Maybe up until the introduced elec fans?
Old Sep 14, 2009 | 09:51 PM
built408's Avatar
F-body pumps will not work without modifications. You either have to pull the pulley out some, or replace it with the truck pulley. I had both the EWP and stock f-body on my truck. I would try that pump, pulling the pullies off is something you don't want to mess with, major PITA. Ask Corey.
Old Sep 15, 2009 | 12:59 AM
I have never personally seen an 05+ pump (or paid attention to it if I have) so I couldn't say.
If you use the "older" 97/98 style with the bold on pulley, its a simple matter of just getting longer bolts and spacing the pulley. I used my 01 pump but had the ability to machine up some spaces to space the entire pump out to the correct location.
Old Sep 15, 2009 | 10:14 AM
fastrt's Avatar
thats why I was going to stay away from a car intake, but with this pump I can swap any intake with a little a/c braket cutting and idler pulley relocation.
and it is a new unit with gaskets, and not having to pull the pulley off is worth the $100.
my 06' pump still has the threads for a manual fan. this one looks like a hybrid
