Using a bigger throttlebody?
Old Oct 29, 2005 | 09:39 AM
Tweaked 5300's Avatar
Default Using a bigger throttlebody?
Just wondering if anybody has or had used a bigger throttlebody on their 99 to present 5300 silverado. i had a 96 c1500 rcsb 5.7L had bought a bbk throttlebody and it improved throttle and mpg so much!! Since my truck is drive by wire i didnt know if there is a improvement or not? Well get to the point i thought fo get it cause i can get it like for less than $100!! so what you guys think?
02 silvrado 5300 auto ecsb
volant
pulleys
MSD wire
Corsa exh
GMS mass airflow
predator
Old Oct 29, 2005 | 10:10 AM
TXsilverado's Avatar
cant go wrong trying it for less than 100. V8 has a bbk on his cable throttle body and gained around 10 hp. i havent heard of any drive by wire gains...
Old Oct 29, 2005 | 03:27 PM
v8
17,16,15,14,13,12,11 Drvr
As long as you get it tuned for it, if not you will run slower, because the a/f ratio will be off.
Old Oct 29, 2005 | 05:05 PM
erronisme's Avatar
wont the computer compensate and re-adjust the A/F ratio?
Old Oct 29, 2005 | 07:22 PM
Yes until you go to open loop/WOT.
During closed loop operation, the computer will constantly adjust to keep A/F 'right.'
Old Oct 29, 2005 | 07:29 PM
v8
correct. I lost 4/10's of a second with the bigger t/b. test at the track same night. same 60'
$A_Money$81
Mar 27, 2023 10:25 AM
Jonblarc7
40
Dec 23, 2015 10:15 PM
old motorhead
Sep 29, 2015 08:22 PM
bluebommer07
Sep 20, 2015 08:42 PM
Alco
Sep 4, 2015 04:08 PM
