turbo is SLOW, test drive report
Old Apr 9, 2004 | 11:47 AM
  #21
parish8's Avatar
single digit dreamer
the cam is sized for a 409, 232/230 590/595 at 114+1
Old Apr 9, 2004 | 01:54 PM
  #22
Keith's Avatar
check out the plug wires that are going to be coming on the lS2:
http://home.comcast.net/~dehudso/LS2.jpg
Courtesy of CarCraft.
Might be the style you are needing. Count me in as one of the jealous of your setup.
Old Apr 9, 2004 | 02:26 PM
  #23
Flyer's Avatar
Did you notice the belt stuff is all in the right place, but backwards for the car guys?
Old Apr 9, 2004 | 03:33 PM
  #24
those look perfect for clearance. To bad they will not be at AutoZone any time soon.
parish, when are we going to get some video and sound of the swsssssssssssss.
Old Apr 9, 2004 | 03:44 PM
  #25
Flyer's Avatar
Open header swish at that
Old Apr 9, 2004 | 03:52 PM
  #26
now he just needs to graft in one of those Banks 4" strait through desiel exhausts, to keep the swish alive.
Old Apr 9, 2004 | 04:20 PM
  #27
parish8's Avatar
i might be able to get some rough video/audio tomorrow, with 2 burnt wires and open exhaust i didn't really think it was ready. i also had to tweak the stuff under the hood to keep the hoses together so it doesn't look as good as it could.
Old Apr 9, 2004 | 04:33 PM
  #28
Hit Man X's Avatar
Originally Posted by LOW2000
Seems like you'd want a tighter stall due to the fact that the turbo is load dependant, not RPM dependant. If you rev it all the way to redline in neutral, you wont see the same boost as you would at 5000rpm in 4th, hence the reason you will now want to run everyone from a punch at highway speeds
Exactly why you don't want to run a 4.56:1 gear set in the turbo vehicle, turbos need something to push against. Also you can't be stalled too low either as the turbo needs exhaust gas velocity to get moving...so having too low of a stall is not good and having your header/manifolds coated helps a LOT in this aspect to retain heat.
I'd say the stall now needs to be around 2500-2900rpms. Sounds low but with the added sudden increase with input torque from the turbo and that planned stroker that's going to be about right. I'd just roughly guess maybe 175-200 ft-lbs when the turbo comes alive with that bigger motor...
Originally Posted by whitt1
Pro-M does make a MAF that's supposed to work,you buy it with a calibrator and software,they scale the MAF to the size injectors you are running then load the calibration on a disk then you download the calibration into the calibrator when you install your MAF/calibrator combo,then they suggest that you tune it further with a wideband O2 sensor.You can scale any combination you like on your laptop.The setup I ordered is supposed to be good for 800+hp.They also make bigger setups some are good for 1200+hp.
Very cool. Well it seems keeping MAF is easily attainable if you calibrate it for the air flow volume that's added and corrected for. Basically gaining you some head room. Doesn't sound cheap but it allows for the drivability of MAF.
Old Apr 9, 2004 | 08:54 PM
  #29
10 Second Club
sweet man. Nothing like a little turbo whistle
Old Apr 10, 2004 | 05:25 AM
  #30
parish8's Avatar
took most of the day off from the truck but did do a little work tonight.
hooked up the hobs switch for the 2nd fuel pump
painted the big 90 at the throttle body
cleaned up the top piping a little, actualy made the BOV pipe section longer
supported the intercooler
hooked up the nitrous and put in 35jets
hooked up the fuel presure gauge
even cleaned up the garage a little
i have some exhaust work to do still, couple of plug wires and then some hard core tuning. then maybe next weekend get some kind of heat exchanger hooked up. probably be a couple of weeks before i have 4wd back.
here is a newer pic
