turbo is SLOW, test drive report
#22
check out the plug wires that are going to be coming on the lS2:
http://home.comcast.net/~dehudso/LS2.jpg
Courtesy of CarCraft.
Might be the style you are needing. Count me in as one of the jealous of your setup.
#27
single digit dreamer
i might be able to get some rough video/audio tomorrow, with 2 burnt wires and open exhaust i didn't really think it was ready. i also had to tweak the stuff under the hood to keep the hoses together so it doesn't look as good as it could.
#28
Originally Posted by LOW2000
Seems like you'd want a tighter stall due to the fact that the turbo is load dependant, not RPM dependant. If you rev it all the way to redline in neutral, you wont see the same boost as you would at 5000rpm in 4th, hence the reason you will now want to run everyone from a punch at highway speeds
I'd say the stall now needs to be around 2500-2900rpms. Sounds low but with the added sudden increase with input torque from the turbo and that planned stroker that's going to be about right. I'd just roughly guess maybe 175-200 ft-lbs when the turbo comes alive with that bigger motor...
Originally Posted by whitt1
Pro-M does make a MAF that's supposed to work,you buy it with a calibrator and software,they scale the MAF to the size injectors you are running then load the calibration on a disk then you download the calibration into the calibrator when you install your MAF/calibrator combo,then they suggest that you tune it further with a wideband O2 sensor.You can scale any combination you like on your laptop.The setup I ordered is supposed to be good for 800+hp.They also make bigger setups some are good for 1200+hp.
Very cool. Well it seems keeping MAF is easily attainable if you calibrate it for the air flow volume that's added and corrected for. Basically gaining you some head room. Doesn't sound cheap but it allows for the drivability of MAF.
#30
took most of the day off from the truck but did do a little work tonight.
hooked up the hobs switch for the 2nd fuel pump
painted the big 90 at the throttle body
cleaned up the top piping a little, actualy made the BOV pipe section longer
supported the intercooler
hooked up the nitrous and put in 35jets
hooked up the fuel presure gauge
even cleaned up the garage a little
i have some exhaust work to do still, couple of plug wires and then some hard core tuning. then maybe next weekend get some kind of heat exchanger hooked up. probably be a couple of weeks before i have 4wd back.
here is a newer pic
here is a newer pic
