Transmission Question
Old Jul 12, 2004 | 07:04 PM
john kilgore's Avatar
Default ratios
Originally Posted by James B.
The TM reduces power by retarding timing during the shift, yes. That's what what is showing up on your logs. What we are really talking about here is the lack of power at the bottom of second gear after the shift due to the huge difference in ratio between the 3.059:1 first gear and 1.63:1 second gear. Every vehicle with a stock converter and a 700R4/4L60E will experience this to some degree.
would 2.66-1.50 be any better?
Old Jul 12, 2004 | 07:49 PM
James B.'s Avatar
Yes, those ratios would be better, but as I've mentioned before - changing planetary sets in an electronic trans like a 4L60E or a 4L80E can only work if the Computer (PCM, TCU, etc) that's controlling it can be configured for the gear ratio constants. Without that ability the computer will interpret the ratio difference as slippage and throw codes. If we were talking about a 700R4 or a TH400 then there would be no problem at all.
Old Jul 15, 2004 | 12:01 AM
1FUNZ71's Avatar
14 Second Truck Club
Is the factory tranny cooler sufficent for the trans go and tt3000?
Old Jul 15, 2004 | 12:44 AM
Hit Man X's Avatar
Spend the extra $50 on a B&M supercooler...
Old Dec 2, 2004 | 12:51 AM
lxcoupe's Avatar
This is a very, very interesting thread for me.
My 2nd gear just went out and I am looking to have my transmission rebuilt.
I sometimes tow a small car (3500lbs) and am curious about transmission upgrades, but I simply cannot do something that will compromise the reliability of the transmission ...
Any suggestions? At this point, I am seriously considering a stock-rebuild.
thanks,
Chris
Old Dec 2, 2004 | 04:52 AM
sfj
would need a tranny cooler and i agree i have a 3k converter and wish i would have went higher so once you get one you will want a bigger one doesnt matter what size you get . i recommend the GM coolers i have heard they are the easiest to install and you cant go wrong with GM especially if someone has to work on it and starts snoopin around
ferrellrooster
Mar 6, 2025 03:22 PM
zblee
63
Jun 10, 2023 01:25 PM
thewrx
Aug 12, 2015 08:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bsn1989
Jul 16, 2015 08:20 AM
