Tire Size Question
Old Mar 4, 2003 | 02:33 PM
BigTex's Avatar
Default Re: Tire Size Question
You are 4wd, right? I launch in either 4hi or auto and dont have traction issues with my Yank 3000. I have yet to spray the converter with nitrous off the line, but I still dont think I'd have an issue. I think you are going to like the Yank. It should work well with your engine mods.
Old Mar 4, 2003 | 03:32 PM
silent1's Avatar
Yeah, I'm a 4x4. It seems that any time I have a question you're the first to reply, thanks. I don't know, but the times I have launched in 4hi I'v gone up 3 tenths slower. How much power can these t-cases hold, I know Parish8 is putting a whole lot through his? Either way, I don't think that 31" tires are the ideal size, what size have you been running?
Old Mar 4, 2003 | 04:44 PM
BigTex's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by silent1:
<strong> It seems that any time I have a question you're the first to reply, thanks. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">We big boys have to stick together against all those little street trucks.
Well, I currently have 31.6" tires. I had a set of 32.8" tires on last year. 99% of the time, I am running my stock tires. The type of tire you run and rubber compound make a difference. My current tires (Michelin Cross Terrains) are heavier than most, but seem to have pretty good grip. Now with my Yank, I'm thinking I may go with a wider profile tire to help with traction a little more.
I get my good time slips with a little help from nitrous. I have found that 4auto cant hold that much power and the rear still spins some. So most of my runs have been in 4hi just so I have traction. If I'm not going to spray it, auto workes just fine.
How is the motor build going? Any progress or decisions yet?
Richard
Old Mar 4, 2003 | 05:56 PM
silent1's Avatar
Well, I'm getting $2400 back from income tax that will be going into the build. I got a hold of some 6.0 heads and I found a local that dedicates his time to LT1 LS1 builds. Since I'm a friend of a friend, he says he can do a stage III porting for $1300! I don't think it'll be done this year since the engine (if built right) will blow my trans and diff, not only that, but I have to up-grade tha fuel system (from what I've been reading in the internal section). So I have a lot to learn and will definitely be bugging you for help as I go along.
Old Mar 4, 2003 | 06:05 PM
parish8's Avatar
single digit dreamer
with the yank i bet you will be faster in 4hi or auto than in 2wd.
couple things i have noticed, when you get more power 4hi is alot smother than auto4wd, auto seems to kick in too late and jars the truck worse. i have 29" tires and would do it again, i am all about ET but they do look a little funny, you might want to go with a little taller tire than me. now for the BIG one, with the stock tires and stock height my truck bounced, jerked and bucked hard. now with shorter wider tires and a 1" drop i am launching smooth and hard. last night i pulled a 1.79 60' and a 3.67 0-60mph and didn't turn a tire. not sure if any of this aplies to you but who knows, it might.
Old Mar 4, 2003 | 10:34 PM
silent1's Avatar
Hey parish, congrats on the new times. I've never had any kind of trouble, bucking or bouncing, when I've launched in 4hi. Right now I'm running 33" MT/R's, I bought these for off-roading and the winter snow. I know what you mean about the truck looking different with smaller tires, it takes me a long time to get used to a 31" tire after I take off the 33"s. I've been contemplating the idea of 4.10's but can't decide for sure, these would definitely help turn my off-road tires.
Old Mar 5, 2003 | 12:47 AM
silent1's Avatar
Default Tire Size Question
What would be the best tire size to run at the track with 3.73's? I was interested in the Hoosier Drag Slicks that were in a post some time ago. They were a 28" tire. Would they be too small or not small enough? I've been running with 31" highway tires, but my Yank 3000 should be here this Friday so I thought I may have some traction problems. The mods will keep coming as long as the money flow is good, that's why I wanted to go all out and get drag slicks now. Is this overkill? Thanks for the help.
stealthperf
34
Feb 14, 2016 11:35 AM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
bsn1989
Jul 16, 2015 08:20 AM
jrplz
Jul 9, 2015 12:07 AM
