Time to order Heads!
Old Jan 2, 2006 | 09:19 PM
  #31
Sport Side's Avatar
I agree... Let the head do the work.
...Every scenario
Old Jan 2, 2006 | 10:48 PM
  #32
Yellowsierra's Avatar
Originally Posted by cablebandit
how much power you trying to make?????????
Its not really how much power im going to make. I just want a head with a thick deck so i dont blow headgaskets as easy and the edelbrock have a thick deck and flow very well. Cablebandit do you think I need an aftermarket head or do you think I will be all right with a GM head, ARP studs and a good head gasket? If the you think the stock GM heads will hold say 15-18 PSI than i will just buy a set of Patriots.
Old Jan 2, 2006 | 11:09 PM
  #33
cablebandit's Avatar
9 Second Club
oh Lord, you are asking dumbass SR. what he thinks!! lol
My 2 cents...i dunno your shortblock but take mine and Daves...5.7...diamond 9:1 compression pistons
Get some #317 heads..STOCK...a 215-220ish cam on a 112-113lsa 93/meth...2 step and a 2600+ stall. Use GM mls gaskets...arp studs. Heads are going to lift with detonation...not power. I lifted heads several times with 200hp less when i used to be too lean or too much timing. I dunno your goals but 700rwhp with a GOOD intercooler should not be a prob if you have the turbo to support it. Once again...i dunno your goals. The cam lsa I said is to help with midrange cylinder pressure since you will be on 93/methanol and you wanna keep that detonation away. I will switch to those same specs next time i have mine apart. Also, exhaust.....that is free power...the freer the exhaust systrm the better for power!!! If you want to spring for ported heads go ahead but i would spend the money on tires!!!!
Old Jan 2, 2006 | 11:25 PM
  #34
Hey jerry heres my setup...
5.7 3.905 bore
Mahle -16cc pistons...8.8-1 with 67cc heads 8.35-1 with 72cc heads
Compstar h beam rods.
Arp main/Head studs
Cometic Head gaskets
Stock Crank 3.622
CompCam 222/218 568/564 115LSA
Garret Turbos 60-1....flow 55+lbs each
Air to Air Intercooler 32"-12"-3"
I think thats about it. Are the heads on your car stock 317's with springs?
thanks
Justin
Old Jan 2, 2006 | 11:40 PM
  #35
9 Second Club
no mine are GTP heads but old ones....i took off some junk ones and picked up nothing...
your call on the heads.
thunder550
Oct 8, 2015 04:53 PM
ZONES89RS
21
Sep 24, 2015 05:58 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Ammadien
Jul 22, 2015 08:50 PM
4B11T
Jul 13, 2015 03:48 PM
