thinking of this cam!
Old Nov 11, 2006 | 07:54 PM
Tahoe6.0's Avatar
how much will the cam / crank gear change the power? move up the power band up?
Old Nov 11, 2006 | 08:11 PM
Wheatley's Avatar
Truck Sponsor
I personally would not do it,not worth IMO
Old Nov 11, 2006 | 08:17 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
advance will bring it down retard will move it up
Old Nov 11, 2006 | 08:19 PM
Go with a set of longtube headers,mill the heads and keep the same cam.
Old Nov 11, 2006 | 08:54 PM
Mr. Sandog's Avatar
I can't believe that someone knowledgeable is recommending a cam swap, especially to a cam that won't give you any increase, noticeable or otherwise. Unless you're going 224/224 or more, there's no sense in swapping.
Old Nov 12, 2006 | 10:47 AM
Tahoe6.0's Avatar
How will the 224/224 work with my set up? My injectors be enough (e85 30lb). Will this be good for a daily driver? Good Torque and Hp to 5500rpm. Maybe I should try this one instead, cam swap are easy enough! Will I lose alot MPG or will engine work easier.
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
steves86ta
Jul 28, 2015 10:21 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
Aboss
Jul 9, 2015 10:28 AM
