Stock Dyno #'s Inside!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 2, 2005 | 11:35 AM
  #91
one03sierra's Avatar
Formerly one92rs
Talking
no there is a table in edit that can be changed that will take care of it. parish and flyer know what it is. blownchevy prolly does to.
Old Jan 2, 2005 | 11:50 AM
  #92
Yeah i will make sure that it is opening all the way this week.
Old Jan 2, 2005 | 02:06 PM
  #93
BigTex's Avatar
There is a seperate limiters table in the PCM for electric throttle. Its labeled as ETC in the limiters section. If you for get this one, the electric TB will clost up on you.
Old Jan 2, 2005 | 02:16 PM
  #94
BigTex's Avatar
Originally Posted by GMC_DUDE
If I'm not mistaken, the LQ9 has a higher CR, 10.0 instead of the usual 9.5, so there will likely be less gain from the radix than with an LQ4.
Not quite so in my opinion. He has the stock pulley, so say its 6 psi. If he is running 93 octane, it should not have any detonation issues at all. Since the pistons are flat tops, it will have a better quench to resist detonation. If both motors can run the 6psi and high enough timing, the one with higher CR will make a bit more power. So at this level of power, there woud be no benefit of the LQ4s lower compression level.
So I think there would be just a bit more gain from a stock radix kit on a LQ9 compared to an LQ4.
Old Jan 2, 2005 | 02:18 PM
  #95
BlownChevy's Avatar
blownerator
25 Year Member
The gains should be the same 100-120 rwhp. He is about 20-25 hp off. I think there is a combination of things going on here, something in the set up. I hate the flowmaster exhaust, it is not good for FI at all.
Old Jan 2, 2005 | 02:19 PM
  #96
BigTex's Avatar
I agree, I don't think its in the blower, and probably not the tune. I'd start with the mufflers too.
Old Jan 2, 2005 | 03:03 PM
  #97
Formerly one92rs
Talking
hey x i remember seeing the ses light on. do you know why it is on? might need to check that first.
Old Jan 6, 2005 | 11:09 PM
  #98
moregrip's Avatar
what a rush!
X- any updates for us?
Old Jan 7, 2005 | 02:25 PM
  #99
Mort's Avatar
snip
BTW: What's a Goatanator???
Something that will outrun a GTO ???????
Old Jan 8, 2005 | 06:27 PM
  #100
moregrip's Avatar
what a rush!
bump
anything?
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
FlowmasterMufflers
Jul 30, 2015 04:29 PM
signguy62
Jul 27, 2015 03:42 PM
4B11T
Jul 13, 2015 03:48 PM
