starting my sierra in cold, having probems
my 2000 sierra with the 4.8 is having a hard time starting in the cold, its all stock other than exhaust to true duals, it starts and almost dies 4 or 5 times and then runs just normal from then on, maybe a choke problem?
Definatly not a choke problem...lol
Do you have a SES light on? Could be a PCV valve, o2 sensor or something small like that...go to autozone and have them scan it for and DTC's, they do it for free..
Does the truck crank slow? If so, may be a battery problem. If it's cranking OK, first things that come to mind are possibly a dirty or faulty IAC valve, fuel pump that is on it's way out, or possibly bad gas. There's a ton of different things that it could be, these are just the first that come to mind. You could try cleaning the throttle body and IAC first and see if that helps...
Mossyoakglock
Aug 28, 2015 12:49 PM
superchomper2003
Aug 26, 2015 09:39 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
