starting my sierra in cold, having probems
Old Dec 12, 2007 | 04:45 PM
zstangboi's Avatar
Default starting my sierra in cold, having probems
my 2000 sierra with the 4.8 is having a hard time starting in the cold, its all stock other than exhaust to true duals, it starts and almost dies 4 or 5 times and then runs just normal from then on, maybe a choke problem?
Old Dec 12, 2007 | 04:48 PM
TravisH's Avatar
Definatly not a choke problem...lol
Do you have a SES light on? Could be a PCV valve, o2 sensor or something small like that...go to autozone and have them scan it for and DTC's, they do it for free..
Old Dec 23, 2007 | 04:46 PM
stockgmc's Avatar
mine did the same thing take it to the advance and have them check your batt/alt.
Old Dec 23, 2007 | 10:45 PM
budhayes3's Avatar
PT's Slowest Truck
Does the truck crank slow? If so, may be a battery problem. If it's cranking OK, first things that come to mind are possibly a dirty or faulty IAC valve, fuel pump that is on it's way out, or possibly bad gas. There's a ton of different things that it could be, these are just the first that come to mind. You could try cleaning the throttle body and IAC first and see if that helps...
Old Dec 23, 2007 | 11:24 PM
dirt track racer 81's Avatar
battery can cause this..seen it happen to a 03 z71 that came in doin this..boss stuck a new batt the guys truck and never happend again
Old Dec 24, 2007 | 07:07 AM
COLDZ71's Avatar
Have the battery checked out first. Would look at the fuel pressure regulator next.
Old Dec 24, 2007 | 05:29 PM
fossil's Avatar
11 Second Club
Does it run roug for a little bit? Reason is we see a bunch of upper intake gaskets leaking when its colder outside. Warms up and gaskets seal off. We
our doing a bunch at work right now...
Old Dec 24, 2007 | 06:03 PM
Onetogofast's Avatar
It might have something to do with your oil, make sure its 5W/30 for cold starts.
shawn96gmc
May 17, 2016 04:15 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
superchomper2003
Aug 26, 2015 09:39 AM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
