Starter for a 4l80 swap in SSS
Old Apr 26, 2016 | 11:33 PM
murderedSS's Avatar
Default Starter for a 4l80 swap in SSS
Hello guys and gals need some help with a part number for a starter for my lq9 I swap a 4l80 in to replace my 65 and I went to prime my motor today and the starter wouldnt reach my flex plate bc of the spacer they told me I needed to go in between my crank and flex plate. Do I need the spacer? And if so does someone have a part number for the starter I need? Thanks
Old Apr 27, 2016 | 12:12 AM
AkSSS's Avatar
I did this same swap on my SS. What flex plate, stock or aftermarket? I used the tci flex plate and I got a 4l80 converter from precision industries.
How far did you pull your converter out of the transmission pump when bolting it up to the flex plate?
Old Apr 27, 2016 | 12:15 AM
Wolftrk99's Avatar
If youre using an actual 4l80 converter and not one of the adaptor converter you need the adaptor! What did you get the flex plate from???
Old Apr 27, 2016 | 02:15 AM
murderedSS's Avatar
I got the adapter plate and flex plate from patc. And I have a precision industries converter built for the flex plate I got from patc
Old Apr 27, 2016 | 02:19 AM
murderedSS's Avatar
Here is the flex plate I have
Old Apr 27, 2016 | 02:20 AM
murderedSS's Avatar
And the spacer I have
Old Apr 27, 2016 | 02:21 AM
murderedSS's Avatar
I guess I assumed the spacer went right on the crank then the flex plate according to the info the flex plate goes on then the spacer? So what's the spacer for??
Old Apr 27, 2016 | 07:27 AM
Wolftrk99's Avatar
To move the flexplate back to mate it to the 4l80 converter, which is the same for older sbc as well as the ls engines....
Old Jun 22, 2022 | 08:11 PM
jose rosas's Avatar
Registered User
I did the Same Swap 4l65 to 4l80 I ordered the 4l80 converter with the bolt pattern for the 4l65 flex plate would i have any issues ? Can I use the old starter ?
jbaum02
Jan 22, 2017 11:28 PM
dhpro
17
Jun 10, 2016 11:23 AM
murderedSS
Mar 29, 2016 09:13 AM
Blwn99x
Mar 22, 2016 05:58 PM
navi5.0yote
Mar 12, 2016 07:12 AM
